Old 03-05-2012, 09:31 AM   #1
Lacross 318BHS Electric Stabilizing Jack issue
Having a problem with the front electric stabilizing jacks. I hit the button to lower them, and while the motor runs, it doesn't seem to catch and lower the jacks. Any thoughts?
John & Amy
jnamadison is offline   Reply With Quote
Old 03-05-2012, 09:53 AM   #2
rracer5's Avatar
It's been awhile since I looked at mine but, when the motor runs, is the big "worm shaft" turning in the stabilizer jack? If not, then look at the back of the motor where the motor shaft and the long "worm shaft" come together. If the motor shaft is turning then you will have to see if you can figure out why it's not turning the worm shaft. It could be just a loose union between the two shafts or a sheared pin that holds the two together. Like I said, it's been awhile since I was under mine and I don't remember the details on the motor/jack assembly.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-05-2012, 10:03 AM   #3
I'll take a look at post back with what I see.
John & Amy
318bhs
