Old 03-21-2013, 02:07 PM   #1
checca's Avatar
Question Lacrosse 318BHS ... Do i have a galley tank?
Question ... on the monitor i see fresh / black / grey / galley levels.
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
checca is offline   Reply With Quote
Old 03-21-2013, 02:39 PM   #2
Commercial Member
Yes, you have 2 gray (kitchen and bath) and 1 black.
PTM
RV Guy is offline   Reply With Quote
Old 03-21-2013, 02:54 PM   #3
checca's Avatar
so the grey and galley monitor levels will always be the same, as the two tanks are tired together to equal the 60 gallons?
Minooka, IL.
Old 03-21-2013, 02:59 PM   #4
Commercial Member
On the 318, yes. The levels in theory should be the same on the monitor but the probes could be set slightly different on the tanks, unit not level, debris on probes, etc. that might cause them to not always read the same.
Old 03-21-2013, 03:03 PM   #5
checca's Avatar
Thanks!
Minooka, IL.
Old 03-22-2013, 09:05 AM   #6
When did they start putting a galley tank in the 318?
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 03-22-2013, 09:39 AM   #7
Commercial Member
Always had a galley gray and bath gray - there are just two pull handles (one for BOTH grays and other for black) so most people don't know it.
PTM
