Old 02-21-2015, 01:44 PM   #11
The_Rhino's Avatar
ChairFlyer, IMO the Lacrosse 329 (@8,800 empty) will push the payload & GCVW ratings of your Suburban 2500...
We really liked the Lacrosse 318 & 329 but chose the Tracer 3150 because it's only 6,500 empty yet still has a slide-out bunkhouse... With family of 5 & our gear, our tongue weight is 1,100, our payload is 2,200, and our GCVW is just below 15,000... Since your 329 is 2,000 lbs. heavier, expect your payload to be around 2,400 & GCVW around 17,000 ready-to-camp... I'm not sure which Suburban 2500 you have, but these are pretty big numbers for the newer 'burbs to handle...
However, I agree that the Lacrosse is a beautiful & roomy TT. You will really enjoy camping with it. Expect your camping neighbors to want to check-it out also - one good way to meet new folks!
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 02-22-2015, 08:14 AM   #12
ChairFlyer's Avatar
Thanks for the feedback. We had the dealer throw in a free Equalizer hitch and new receiver for our Suburban so we will try that setup and see how it does. I've heard nothing but good about the ProPride hitch, but the cost is a factor for us. If the Equalizer doesn't do the trick, we may spend the bucks. Right now, the next big decision for us is picking out the slide toppers for the 329. The dealer is recommending AE toppers and the 3 color choices are white, black and satin. Does anyone have any suggestions? I prefer black, but my wife thinks they would fade after a few years and would cause extra heat buildup. Don't know how white would look with the Champagne color. We are going to also install the Fantastic Vent covers in a Smoky color. Decisions, Decisions.
We have a 1999 C2500 Suburban with a 7.4L engine and a 4.10 axle. We bought it new and have taken great care of it (hasn't even passed 100K miles yet). It is rated at 10,000 lbs towing capacity and in 1999 there is no published GCVR I can find. We had the Suburban weighed and we will be well under the GVWR and the max axle weight limits. Our Lacrosse weighs 8759 dry (with 2 air conditioners), so that gives us 1241 lbs for stuff (even though the 329 can carry 2200+ lbs). We usually pack about 1000 lbs for a typical trip (there are only 3 of us), so we should be OK. Not planning any trips out west for a few years, so most of our towing will be on relatively flat terrain. We will get a new tow vehicle in the next few years, after we get our money's worth out of the Suburban.
Anyone have any suggestions for bike racks? Our old Cougar had the bike rack on a pull out platform which was really handy. Has anyone mounted a receiver to the bumper for a bike carrier?
ChairFlyer is offline   Reply With Quote
Old 02-22-2015, 08:29 AM   #13
Platokidd's Avatar
Originally Posted by ChairFlyer View Post
Right now, the next big decision for us is picking out the slide toppers for the 329. The dealer is recommending AE toppers and the 3 color choices are white, black and satin. Does anyone have any suggestions? I prefer black, but my wife thinks they would fade after a few years and would cause extra heat buildup. Don't know how white would like with the Champagne color. We are going to also install the Fantastic Vent covers in a Smoky color. Decisions, Decision.
Look into this last summer for my Lacrosse.
White is the cheapest and Black does look cool with champagne.
Liked the EZ line from dometic, but think acrylic fabric would hold up better then vinyl . (carefree toppers).
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 02-22-2015, 10:21 AM   #14
We tow ours with a Cummins Ram 2500 and about half the time I don't even put the sway bar on it. I think that as long as your suspension is pretty tight (good ball joints, tie rod ends, and the like) and you are running good LT tires like Michelins at 80PSI (check your rim ratings!) you will be fine. LT tires running at maximum tooth jarring pressure do not have a lot of squirm that I feel lets the trailer start swaying and gets ugly from there.
I have towed some big equipment trailers with a 454 before and that is a great engine for pulling, but it does suck down the gas. You should stick with premium gas when you are loaded to keep the pinging down, you don't want to knock a hole in a piston. We used to tow big hay trailers with mid 70's 454 1 ton trucks and between 20 round bales and the trailer it would be over a 20K pound load and the engines never gave problems, just burned clutches from 16 year old drivers.
MickeyD is offline   Reply With Quote
Old 02-22-2015, 11:03 AM   #15
The_Rhino's Avatar
The 1999 C2500 Suburban w/ 7.4L 454 & 4.10 axle is a beast compared to some newer 'burbs, so it looks like you are good to go... I agree that you should start-out with the Equalizer 4 (& tweak it at full payload) before spending more.
Although the 454 is a real guzzler by today's standards, buying anything new that will tow the same is big bucks. So IMO you are better-off paying extra for gas vs. payments on something newer especially since your 'burb seems to well cared-for. Enjoy your first season out with the new Lacrosse!
Old 02-22-2015, 04:51 PM   #16
I know most people seem to be pulling the 329BHT with 3/4 ton or 1 ton units, but is there any reason the new 2015 half ton Ford's can't pull it? Looks like the ratings should handle it (11,500 lb towing capacity and over 2,000 lbs in payload).
art_vandelay is offline   Reply With Quote
Old 02-23-2015, 12:43 AM   #17
After having pulled one (not very comfortably) with a 14' GMC CC 4x4 6.5' bed with the 5.3 engine I am sure that it will pull it down the road but the trailer is going to be in charge. The 329 does not look that big when it is on a lot with other trailers jammed in tight, but when you have it hooked up to a truck you see that it is a BIG trailer with tall (about a foot taller than most) wind catching sides. If you were just pulling that much weight on a lowboy trailer it would do fine (my 14' GMC pulled a 14K pound equipment trailer without much complaint and it was a very stable tow) while the 329 pushed it around a lot in traffic on the interstate. It did not feel safe and I did not want to put my family at risk to the point that I traded in an almost new truck and took a $3500 hickey on it plus spent a crapload more money going to a 2500 diesel.
The replacement Cummins Ram 2500 weighs close to 9K pounds with the deer bars on the front and the extra fuel tank and toolbox and that weight comes in handy in controlling the trailer, it is actually a pretty relaxed ride even in heavy traffic. If you load the trailer up with a bunch of stuff (like everyone does) it is going to weigh almost twice what the new aluminum Ford will, and with a bumper pull that does not sound like a recipe for relaxation. I suspect a fifth wheel would pull a lot better than a trailer will with the new light weight trucks from applying the load (and sideways motion) over the rear axle instead of levering it out 4 plus feet behind it.
Old 02-23-2015, 04:54 AM   #18
Platokidd's Avatar
It will tow it, better if the trucks has proper equipment. Lot depends on the driver as to how well it handles. Or what you the driver can handle.
To me the mfg tow rating dont mean all that much.(sales pitch) Only the dodge uses the J2807 standard last I looked.
So right now Im in the 3/4 ton crowd as my truck does a great job
nights of camping
Seasonal
Old 02-23-2015, 12:05 PM   #19
Thanks for the info. I'm going to research the F150 a little more, but it still looks like the specs can handle it. Our camping trips are within a few hours of where we live, so we're not driving it too often. Right now my gut is telling me that the F150 can do the job.
We love the layout and the large fridge which is why we're considering the 329BHT over anything else right now.
Old 02-23-2015, 02:12 PM   #20
The_Rhino's Avatar
As noted on my other posts, I seriously considered trading-in my Ram 2500 for a F150 EB HD to get better mileage on my daily commute, but I don't want to give--up my Ram's 3,000 lb. payload. Those beefy springs not only handle the 3,000 lbs. but they keep the rear-end very stable on curvy 2-lane highways, high winds, etc.
Specs are one thing & then there is real world experience. For a number of years I worked for (3) different companies towing commercial trailers with any number of 1/2, 3/4, and 1 ton trucks. IMO the biggest issue was continually repairing brakes, bearings, front ends, broken springs, etc. when trucks were pushed near their specs. However, at some point I had white knuckle experiences with each.
For instance, on a two lane highway, a young teen missed a stop sign & slid to stop blocking my lane. With a flatbed carrying (2) Kubota backhoes, I had just enough time to swerve around her and get back into my lane before risking hitting oncoming traffic... Although the F150 had the "specs" to tow this load, I was sure glad had the 1 Ton that day...
That said, I can't afford a diesel 1 ton as my daily driver but I feel the 3/4 ton I have is very capable & safe match for the TT & gear we haul.
lacrosse
