Old 09-02-2013, 10:26 AM   #1
Walke's Avatar
Lacrosse Owners
Do any of the Lacrosse Owners on this site tow with a Hensley Hitch?
I have a question for you !
Ken & Judy
2012 Prime Time Lacrosse 301RLS
2014 Ford F-150 Lariat - Max. Tow - Ecoboost
Hensley Arrow Hitch
Average 50-60 nights/yr
Walke is offline   Reply With Quote
Old 09-03-2013, 07:26 AM   #2
Wildwood Danny's Avatar
We do tow our Lacrosse 303RKS with a Hensley, wouldn't think of leaving home without it. What is the question?
2006 Silverado 2500HD
2007 Hensley Arrow Hitch
Good Sams Club, Cedar Creek Sams Chapter
RVing is a tough job,BUT someone has to do it!
Wildwood Danny is offline   Reply With Quote
Old 09-03-2013, 08:16 AM   #3
Walke's Avatar
Thanks for the reply Danny, I wouldn't leave home without it either.
I wanted to ask, (a) if you have taken it on long trips ( 2000+ miles) running 6-7 hours per day? and (b) in doing this are you having serious wear on the inside edge of your tires on the rear axle? (We go to Florida every winter)
My theory is the Hensley hitch by design has a slight motion side to side that we do not feel but the rear axle would feel this motion. (long fulcrum) I had the rear axle checked and it is not bent. The wear is also very uniform on both rear tires.
Ken & Judy
Hensley Arrow Hitch
Old 09-03-2013, 08:24 AM   #4
All my tires are wearing about the same, the rear one's maybe a little more. I do notice that the rear axle seems to scrub when making tight corners, due to the distance between the axles being greater than trailers I have had in the past, but don't think it has anything to do with the Hensley...
Hope this helps, might also weigh the each axle to see if they are near carrying the same weight, then you can make adjustments with cargo placement and Hensley adjustments to balance out, takes a little time.
Old 09-04-2013, 06:24 PM   #5
Platokidd's Avatar
... Air pressure good? overloaded? Tires alignment look good ?
Interesting theory,, could be something to look more into
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 09-10-2013, 07:09 PM   #6
Platokidd's Avatar
It just came to me Duh.. I had that problem of wheel wear on my wilderness. Check your wheel bearings. Turned out all my bearings were worn out causing the tires to lean and wear on the insides more.
nights of camping
Seasonal
lacrosse
