Old 01-15-2012, 04:09 PM   #1
Rustymax's Avatar
Location: Close to North / South Carolina border and Blue Ridge Mountains
LaCrosse Queen Mattress mods
Re: LaCrosse Queen Mattress
We would like to know what solutions others have made to their Short Queen Mattress in the way of toppers. Currently Costco has a reg Queen ( 80" L x 60" W) Novaform Gel Memory Foam Topper on sale, but I was curious if this type of mattress can be trimmed to size (gel?) without too much difficulty. The corners are also square. The cut-away view of the mattress (on the box) looks as though the mattress is mainly foam inter-sprinkled with gel beads. The option for Sleep Number mattress is too expensive. Please share your thoughts and successful mattress modifications.
Thanks!
Mrs and Mr. Rustymax
Rustymax is offline   Reply With Quote
Old 01-15-2012, 04:24 PM   #2
M109Rrider's Avatar
Had a pillow top on the short queen in our old keystone. We just let it drape over the front and back and stretched the fitted sheet over it.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 01-15-2012, 11:24 PM   #3
Don't call me Junior!!!
The DW and I just went through this. New Trailer for us so the comfort of the bed was important. We purchased a queen sized memory foam (2.5") from Sams Club and a Pillow top to go over that. The mattress from the factory might as well have been a ply-wood sheet it was so hard. The addition of these two items helped out tremendously. Its not a sleep number but for under 200 bucks it isnt bad at all.
We did not cut anything as the overhang helps use up some of the left over mattress cover and sheets.
Best!
2012 Tracer Executive 2600RLS
2011 Chevy Tahoe HD Towing Pkg
BubbaTex is offline   Reply With Quote
Old 01-16-2012, 07:52 AM   #4
phrogdriver93's Avatar
We bought the exact Novaform gel mattress topper that you are referring to. The bed is now very comfortable and I trimmed it using a normal pair of scissors. Would highly recommend.
phrogdriver93 is offline   Reply With Quote
Old 01-16-2012, 03:31 PM   #5
We have a 230 Tracer, with a 60 x 74 mattress that was too hard for our tastes. We put a 60" wide 6" diameter round bolster pillow at the head of the bed and cut a memory foam topper to fit the combination, that is, 60 x 80. A standard fitted cover went over that, and normal sheets / comforter on top. Since there was some room between the foot of the bed and the back of the entertainment center no mods to the trailer / bed were needed. The plywood under the bed isn't as long as the mattress, but it hasn't been noticeable, and if it does become a problem I can cut another 6" longer piece of plywood to replace it.
Roamin Ovum is offline   Reply With Quote
Old 01-16-2012, 07:20 PM   #6
We also added the memory foam topper. We just moved the mattress away from the headboard about three inches, and placed the topper flush with the headboard. This configuration works fine without trimming the topper. It sleeps almost as good as our tempurpedic at home. We just got home from a nice trip to Stone Mountain, GA. Enjoy!
James and Karen
Warner Robins, GA
2011 Lacrosse 301RLS
2007 Tundra CM 5.7
Reese Dual Cam
jjarrard is offline   Reply With Quote
Old 01-17-2012, 10:50 AM   #7
rracer5's Avatar
Yup......Same here with the Walmart 2" memory foam topper and a queen heavily padded mattress cover. We just let the topper fold over the head of the bed with the padded mattress cover also and just tuck it all under the head of the bed. This also makes the bed just a little longer too. It's a whole lot more comfortable then the standard mattress that came with the TT.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
