Old 11-12-2012, 10:02 AM   #1
Landing Gear Problem
Hi all.
Got a 2011 Crusader 270RET with the motor-driven landing gear. Recently (accidentally) extended gear to the stops at both ends. Now, one side does not extend as fast as the other - only about half as much. They retract at the same speed, so now I have one side that's longer. I suspect I may have stripped the gears on the slow side.
Anybody experienced / repaired this?
Thought there was a flyer in the manuals about the landing gear system, but I can't seen to find that now. I assume the landing gear is a Lippert system, as everything else is -- can anyone confirm? The Lippert parts site has "Landing Gear Leg Repair Kit[s] by Venture", so perhaps Venture actually manufactured the components?
Thanx in advance for any insight here :-)
2008 F-250 Diesel
NottieMatt is offline   Reply With Quote
Old 11-12-2012, 10:17 AM   #2
rattleNsmoke's Avatar
Try again?
rattleNsmoke is offline   Reply With Quote
Old 11-12-2012, 10:21 AM   #3
Sorry - fat fingered a button and it posted before I was done typing. I edited the original post.
2008 F-250 Diesel
Old 11-13-2012, 04:05 PM   #4
Commercial Member
Nottie - perhaps our Customer Service folks can give you a hand if you want to send them an email at Prime Time Manufacturing, Manufacturers of travel trailers and fifth wheels
Best of luck.
PTM
RV Guy is offline   Reply With Quote
Old 11-14-2012, 08:44 AM   #5
Having done some more research, I think I need to pull the slow leg out and see if I can tell what's actually wrong -- did I strip one of the beveled gears at the top or did I strip the jack nut / screw? Then I'll call customer service and see what they reccommend.
2008 F-250 Diesel
