07-12-2015, 09:21 AM
#21
Originally Posted by CMSgt (Ret) Charlie Brown
When leveling side to side and for example, your right side is low. Do you shorten the legs on left side to help compensate for height difference on right side? We have a Crusader and when the rear is low, we shorten legs in front to compensate. Does the same principle work side to side?
I'm not sure which Crusader model you have, but ours has the leveling system, not stabilizer jacks. We use the leveling system for side to side in addition to front to back.
As you suggest, we drop the pins a bit lower on the low side (the most we have had to do is a difference of four holes) It has worked for us. We always ensure the tires do not lift off the ground.
Although I carry two 2X8's I have yet to use them, and in fact we just discussed getting rid of them as the trailer has been able to compensate for uneven sites to this point.
2014 Crusader 351 REQ Touring Edition (the Cottage)
2015 GMC Sierra 3500HD SLT (Allison B)
Nights in the Cottage: 2014: 27, 2015: 80 2016: 47,[B]2017:41
2018: Jan= 2, Feb=2, Mar=3, Apr=2, May=7, June=5, July=15, Aug=1,Sept=2,
Running Total:232
07-12-2015, 11:13 AM
#22
I have tried the Anderson leveler, wood, and lock blocks. I use the anderson occasionally, mostly for paved or gravel sites. However, 90% of the time I use the blocks. I also use the blocks under the stabalizer jacks. They are very easy. You pull in where you want to park, analyze how far off you are slightly back up, place the blocks, and then pull onto the blocks. Easy with a partner to let you know when to stop.
The blocks are light and you can carry quite a few of them in a fairly small area, making for efficient storage.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
07-12-2015, 02:13 PM
#23
I just looked and I can lower on of my front jacks 16 inches lower than the other. I would block the wheels on the low side so as not to twist the frame. That would be one heck of an uneven spot !!
While your 5th wheel is still on your truck it should be close to level so you can see what blocks and how much you need to adjust your jacks.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
07-12-2015, 02:55 PM
#24
We have a 330 MKS with the 4 point leveling system. But someone has shared on this topic that the rear jacks are not for leveling but for stabilizing only. They are not really load bearing since they are right behind the tires.
07-12-2015, 03:05 PM
#25
Always Learnin'
Leveling
I invested in a set of the Anderson leveler, red, curved wedges with chucks. I bought two. I had to cut a few inches off the tip of one so it fits between the tires; as suggested in their instructions. They work slick and quick. I put them under the tires on the low side. The DW backs or drives forward. I check the level, directing DW to pull ahead or back up as needed. Once level I put the chucks in, leveling done. No repeated driving on and off a stack of whatever. When I ordered them (from Amazon) I was reluctant given the price. They work soooo quick and slick, it was worth the investment.
07-12-2015, 03:47 PM
#26
That was me but I don't have the leveling system like you have. I only have front landing gear and rear stabilizers. I would imagine your leveling system is weight bearing but I'm not familiar.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
07-12-2015, 05:57 PM
#27
Something that I have found quite useful is an iPhone app called RVC Free. You place it on the floor, or elsewhere, & it not only shows the level in Both directions, but also the Estimated Thickness required to bring the trailer to level. Saves time putting a 2" spacer in place & finding you only needed 1", etc. You do have to initially calibrate it, but that takes into account your case etc. & a one time exercise.
2021 Forest River Vengeance Rouge Armored 371A13
2021 GMC Sierra/Denali 3500HD SRW
Anderson Ultimate 24k Hitch
07-12-2015, 06:02 PM
#28
Alleged curmudgeon
Originally Posted by Papa GLS
Lynx levers work for me if site is not too unlevel side to side. Much lighter & easier to carry than a bunch of wood. Have 1 4"x6"x1.5' for tongue jack.
x2
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
07-12-2015, 06:32 PM
#29
Originally Posted by Vern
x2
X3 with a mea culpa. Bought my first TT with slides. As with my "old" TT, used stick-on bubble levels for front/back, side to side. Get to first campsite, level perfectly. Extend slides and find bedroom door won't shut properly. Breakout phone with leveling app, it says I'm unlevel. Go outside, the side to side bubble level is off. Scratching head when (figurative) light bulb illuminates. Two slides on one side change the center point and weight distribution. DUH. Live and learn.
2016 Open Range 319RLS
2015 Ram 2500 Laramie Longhorn Limited 6.7 Diesel
07-12-2015, 06:41 PM
#30
Anderson Levelers. Hands down, they are straight up awesome. However, this last trip I had to shove a board under them due to extremely wet ground.
TV: 2018 Ford F-350 Powerstroke
Trailer: 2013 Palomino Puma 27SBU
07-12-2015, 07:42 PM
#31
ikss owner i use Anderson levelers they work amazing.
07-12-2015, 07:43 PM
#32
Do you mean RV Companion Free?
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
07-12-2015, 08:00 PM
#33
Always Learnin'
RVC app?
I couldn't find a app, RVC, but did find several 'level tool' apps. I am so amazed by all the things that can be done on iPhone.
07-12-2015, 08:06 PM
#34
Has anyone ever heard leveling your camper by leveling your fridge?
Jason and Billie
2018 F-250, 6.2L
07-12-2015, 08:21 PM
#35
Huh? Typically my fridge levels as i level my camper
Sent from my SM-N910V
07-12-2015, 08:31 PM
#36
While researching ways to make my fridge work better I found a recommendation of using a torpedo level in the freezer to use as guide for mounting outside bubble levelers.
Jason and Billie
2018 F-250, 6.2L
07-12-2015, 09:06 PM
#37
Yes, you are correct. It has several other items ie To Do, Camps, Trip Log, etc.
After I initially calibrated, I leveled the trailer using the freezer surface. I then found a spot on the floor, near the door, that matched the readings & I now use that location. Don't want to be opening fridge all the time, but that is what is really critical.
07-12-2015, 09:50 PM
#38
Another satisfied Anderson user here.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
07-12-2015, 10:16 PM
#39
You are correct. This is from Dometic:
Caution
Do not park your RV on a slope for a longer period of
time. Absorption refrigerators use a gravity-flow system.
Being on an angle of more than a couple of degrees for extended
periods of time stops the refrigeration and might
cause damage to the cooling unit.
Also explained here:
07-13-2015, 07:04 AM
#40
Originally Posted by youroo
Side to side leveling! Youroo!!
Youroo,
Where did you get those ramps?
