Old 07-12-2015, 07:42 PM   #31
ikss owner i use Anderson levelers they work amazing.
muskoka01 is offline   Reply With Quote
Old 07-12-2015, 07:43 PM   #32
strat56's Avatar
Originally Posted by ACE110 View Post
Something that I have found quite useful is an iPhone app called RVC Free. You place it on the floor, or elsewhere, & it not only shows the level in Both directions, but also the Estimated Thickness required to bring the trailer to level. Saves time putting a 2" spacer in place & finding you only needed 1", etc. You do have to initially calibrate it, but that takes into account your case etc. & a one time exercise.
Do you mean RV Companion Free?
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 07-12-2015, 08:00 PM   #33
Always Learnin'
Bullgould's Avatar
RVC app?
I couldn't find a app, RVC, but did find several 'level tool' apps. I am so amazed by all the things that can be done on iPhone.
Bullgould is offline   Reply With Quote
Old 07-12-2015, 08:06 PM   #34
M109Rrider's Avatar
Has anyone ever heard leveling your camper by leveling your fridge?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 07-12-2015, 08:21 PM   #35
Huh? Typically my fridge levels as i level my camper
Sent from my SM-N910V
mustardbucket107 is offline   Reply With Quote
Old 07-12-2015, 08:31 PM   #36
M109Rrider's Avatar
While researching ways to make my fridge work better I found a recommendation of using a torpedo level in the freezer to use as guide for mounting outside bubble levelers.
Jason and Billie
Old 07-12-2015, 09:06 PM   #37
ACE110's Avatar
Yes, you are correct. It has several other items ie To Do, Camps, Trip Log, etc.
After I initially calibrated, I leveled the trailer using the freezer surface. I then found a spot on the floor, near the door, that matched the readings & I now use that location. Don't want to be opening fridge all the time, but that is what is really critical.
2012 Forest River Wildcat 313RE
2012 GMC Sierra 2500 HD Duramax
Demco Hijacker 18K Autoslide Hitch
BAK Roll-X Tonneau Cover
ACE110 is offline   Reply With Quote
Old 07-12-2015, 09:50 PM   #38
UmptySquat's Avatar
Another satisfied Anderson user here.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 07-12-2015, 10:16 PM   #39
cwppwc's Avatar
You are correct. This is from Dometic:
Caution
Do not park your RV on a slope for a longer period of
time. Absorption refrigerators use a gravity-flow system.
Being on an angle of more than a couple of degrees for extended
periods of time stops the refrigeration and might
cause damage to the cooling unit.
Also explained here:
2016 Open Range 319RLS
2015 Ram 2500 Laramie Longhorn Limited 6.7 Diesel
cwppwc is offline   Reply With Quote
Old 07-13-2015, 07:04 AM   #40
Originally Posted by youroo View Post
Side to side leveling! Youroo!!
Youroo,
Where did you get those ramps?
COPPERJK is offline   Reply With Quote
leveling
