Old 02-09-2013, 04:33 PM   #1
wmcclay's Avatar
Lights
We have many ceiling lights in our sanibel, have one not lighting. Called the stealer (dealer) and asked how to remove the cover to replace the bulb. Silence, so does or has anyone removed the ceiling light cover in a Sanibel?
I played around but did not want to break it. Monday I will call customer service, if no answer here.
Wayne and Donna
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 02-09-2013, 04:44 PM   #2
TURBS's Avatar
Do you have a pic of said lights?
Old 02-09-2013, 04:44 PM   #3
Commercial Member
huntr70's Avatar
If I remember correctly, it has the flush mount frosted glass lenses??
I think you actually twist them one way (I forget which way) as the lenses are notched.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 02-09-2013, 04:59 PM   #4
Earth Station's Avatar
not sure if your lights are the same but you might want to check the thread Columbus LED Lights
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 02-09-2013, 06:00 PM   #5
Those are not LED lights. I've opened mine; no twist. You just pull on one side and it will come out. I agree that it takes more force than you're comfortable with. (I actually found a discarded instruction sheet for those lights that didn't get cleaned out somehow, and that was the instruction there as well.) Just pull one side.
Old 02-09-2013, 07:12 PM   #6
I guess I could add that those are G4 12v, 20watt bulbs.
Old 02-10-2013, 10:42 AM   #7
wmcclay's Avatar
I want to replace them with leds 4 to 6 at a time, there are too many to replace all at the same time. Thanks for the info, wiil order some monday.
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
Old 02-10-2013, 10:50 AM   #8
Wayne, I'd take a look first. I kinda doubt that there's room for LEDs in there. It's pretty tight. Also, I don't think they make LEDs that are that bright (but that's probably ok).
Old 02-10-2013, 07:21 PM   #9
LKicklight's Avatar
Led's
Go look at Superbrightleds.com
they have just about any kind of bulb made..all are led's...just purchased twenty led bulbs for our crusader 270ret...they really make a difference and are brighter than the holgen bulbs..
LKicklight is offline   Reply With Quote
Old 04-05-2013, 11:30 AM   #10
I had ordered one of these G4 LEDs to try in those hockey-puck ceiling lights. I found that they work great! They actually may be a little brighter than the 20w bulbs that are in there now! Note that this is the wide-voltage-range bulb. They make the same thing that is 12-volt only. I don't trust those to last very long in an RV.
Unfortunately, they do not work (fit) in the under-cabinet lights. These are the ones I was really anxious to replace because they get so hot.
If anyone has found a good solution for those, let me know. I may try to see if it's possible to remove the reflector in them.
I also replaced the 5 1076 bayonet bulbs over table & sink with these 1142 LEDs. They are not as bright as the 1076's, but we always felt that those were too bright anyway. We like the result.
