Old 08-17-2014, 07:22 PM   #11
Jimmygee's Avatar
We will look at the wiring closer tomorrow.
Jimmygee
2010 ford f150 lariat super crew 5.4 373 rear hd tow pag
2011 tracer 2800 RDL w/4 point equal-i-zer hitch
Nights spent camping in 2011 - 48
nights spent camping in 2012 - 50
nights spent camping in 2013 - 14
Jimmygee is offline   Reply With Quote
Old 08-17-2014, 08:43 PM   #12
rracer5's Avatar
Originally Posted by wowzer View Post
This happened to me....check your wiring under your slide. I would be willing to bet it has caught on something and has cut them.
X2 Definitely sounds like the 12v wires to the slide have been pinched and/or cut. Quite sure all wiring runs from the frame and are held up by "straps" as the slide goes in and out. The slide out motor is located under the main floor of the TT at the end of the ram/gear assembly therefore, not affected.
One more thing.....are there amber marker lights on the outside of the slide and if so, are they or it working?
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-18-2014, 07:29 PM   #13
Jimmygee's Avatar
The running lights on the slide work but the front door light on the opposite side stopped working.
Jimmygee
Old 08-18-2014, 07:50 PM   #14
Arefbee's Avatar
Looking at our trailer, it looks like those lights are on a fuse in the panel. It is a second fuse from the bottom. If the fuse is burned out the LED next to it will be lit. So best thing is to look at the panel.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 08-20-2014, 02:26 PM   #15
Just solved the same problem
I just had the same problem with my Forest River 5th wheel. None of the fuses were blown, but my daughter informed me that the lights flickered before they went out. I then pulled the switch out of the wall and started pulling the wires up and sure enough, the wire nut holding the 4 wires together was completely burned up. After cutting them past the burn and giving them about 1/4 inch of wire, I checked the ohm reading to each of the lights it was powering and they all came out perfect, so I'm guessing the installer just didn't tighten the wire nut enough and it was arcing, eventually causing it to burn up. Works like a charm now.
Dan
Venturemmltd is offline   Reply With Quote
Old 08-20-2014, 06:16 PM   #16
Jimmygee's Avatar
Thanks Dan, we will try that this weekend.
Jimmygee
Old 08-21-2014, 09:10 AM   #17
another_newfie's Avatar
We recently had an issue with the lights in the slide on our 295RST. Turned out to the clasps that hold the fuse on in the converter. It was very hard to see at first.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
light, slide, slide out
