Old 03-04-2012, 05:55 PM   #11
I installed a cheap toggle switch from Radio Shack beside the bedroom radio so the light goes out.
2004 GMC Sierra 2500
2012 Primetime Crusader 298BHD
sbelliott is offline   Reply With Quote
Old 03-05-2012, 09:06 AM   #12
Pictures requested
Thank you Jtad. Could you post pics on the location of where you installed your disconnect switch to the batteries?
Joe
Drdepjoe is offline   Reply With Quote
Old 03-05-2012, 11:05 AM   #13
jtad's Avatar
Yea Joe no prob. I am on duty today, it will be tomorrow before I am home. But I will shoot you a couple and get them up as fast I can.
2011 Cursader 298 BHD
2012 F-250 FX4 6.7 Power Stroke
B&W Companion Hitch
Days Reserved for 2012: 39
jtad is offline   Reply With Quote
Old 03-05-2012, 11:40 AM   #14
We were pleasantly surprised to find a battery disconnect in our new 2604. It's right below the refrigerator, although the battery is in the front. BL
BIG LACY is offline   Reply With Quote
Old 03-05-2012, 12:50 PM   #15
TURBS's Avatar
Originally Posted by Drdepjoe View Post
The problem is I am unable to locate the battery or the disconnect.
after thinking about it I dont think I would want to buy from your dealer ! If he/they didnt even show you where your battery and or disconnect is Im affraid of the bad information if any you did get ! Not to mention if they failed to show you something as simple as the battery what else didnt you get info on !
by pass valve
hw heater on/off switch
water filter
how long was your pdi ?
Old 03-06-2012, 02:23 PM   #16
jtad's Avatar
Switch pics
Hey Joe here a couple of pics. You will need a switch and a batt cable. Just messure how far from the batt to where you are going to mount the switch and thats how long a cable you will need. Maybe get it just a little longer, better to be safe than sorry. Most auto parts stores will have these cables already pre made in differnt leanths. Just disconnect the ground side of the batt, run it to one side of the switch. Run your new cable from the other side of the switch to the ground side of the batt. Keep in mind I mounted my switch where I did because the original ground side batt cable would reach it without having to extend it. Hope that makes sense.
ID:	10767   Click image for larger version
ID:	10768   Click image for larger version
B&W Companion Hitch
Old 03-06-2012, 02:50 PM   #17
RossandDonna's Avatar
Thanks for the great pics jtad. I assume the multi wire cable on the left is the original negative battery lead and the single cable on the right is the new negative lead to the battery.
PS. what local are you with?
2012 Crusader 290RLT
2013 F350 Lariat Crew Cab DRW 6.7L Diesel
RossandDonna is offline   Reply With Quote
Old 03-06-2012, 02:52 PM   #18
jtad's Avatar
That is correct.
B&W Companion Hitch
Old 03-06-2012, 03:36 PM   #19
TURBS's Avatar
My vote is for positive
Old 03-06-2012, 05:20 PM   #20
dilgerc's Avatar
So are you saying you put the switch on the neg wire? Why is that, I would have thought you would want to put the switch on the positive side. Just curious
dilgerc is offline   Reply With Quote
battery, battery disconnect
