Old 03-01-2012, 07:54 PM   #1
Unhappy Location of battery disconnect
I just purchased the 2012 crusader 290 RLT. Does anyone know where I can find the battery and battery disconnect. The radio in the bedroom stay lit all the time. I want to disconnect the 12 volt power. Thanks.
Drdepjoe is offline   Reply With Quote
Old 03-01-2012, 07:57 PM   #2
TURBS's Avatar
do you even know that it has one ?
normally its located within a few feet of the battery .
Old 03-01-2012, 08:12 PM   #3
The problem is I am unable to locate the battery or the disconnect.
Old 03-01-2012, 08:28 PM   #4
RattVader's Avatar
If it is setup similar to the 320,you will find the battery in the very front compartment,the basement I believe they call it,facing the front of trailer,right hand side.Hope that helps. As far as a battery disconnect goes there is not one.I installed my own.Not that hard.
Steve & Sue
2011 Crusader 320RLT
2008 Dodge Ram 3500 (CTD) DRW 4x4
RattVader is offline   Reply With Quote
Old 03-01-2012, 08:32 PM   #5
M109Rrider's Avatar
As already said, doubt you have one. I installed my disconnect on the front of battery box where it hangs down.... easy access.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 03-02-2012, 08:54 AM   #6
Commercial Member
The Crusader does not have a factory installed Battery Disconnect. It's not unusual for the dealer to install one, so I can't say for sure on your unit.
Generally, your batteries are dealer installed in the front storage compartment where we run all of the wiring along with a battery box, vent hose, and vent.
Hope this helps.
PTM
RV Guy is offline   Reply With Quote
Old 03-02-2012, 11:32 AM   #7
Battery location and disconnect
Thank you all for the replies. Where might I find a battery disconnect that I can install myself. Camping World?
Thank you all!!!
Joe
Old 03-02-2012, 12:07 PM   #8
Triguy's Avatar
Amazon.
A simple on/off disconnect.
another for switching batteries or battery banks..
There are other models, too, that are not as weather proof but are fine for indoor placement. A little cheaper, too, but those above are under $30.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-02-2012, 02:22 PM   #9
jtad's Avatar
Bought mine at NAPA, but any auto parts store will have them for 20-25 bucks. I installed mine where you open the driver side door where my propane tank is. Just reach in flip the switch. Super easy to install, I can post pics if you want or need any help just hollar.
2016 Dynamax DX3 37BH
2015 Jeep JKU
jtad is offline   Reply With Quote
Old 03-02-2012, 02:22 PM   #10
Thank you! I will proceed and purchase one to install.
battery, battery disconnect
