Old 01-01-2012, 04:06 PM   #1
Lock Arm Stabilizing Bars
I have a Crusader 2012 290 RLT that I thinking of putting on a set of Bal Lock Arm Stabilizing Bars on. I would like to dampen the movement while set up and I understand that the lock arm bars will help a lot. I was wondering if anyone has put them on their unit and whether the enclosed under carriage presented a problem with the installation. I would sure hate to puncture a tank or a electrical line.
kmfujino40 is offline   Reply With Quote
Old 01-01-2012, 05:26 PM   #2
camping
tentcamper1's Avatar
heres a post I found helpful, i made my own and they work great.
Steady Fast Stabilzer System
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 01-01-2012, 06:08 PM   #3
lindy's Avatar
I too made my own for about $54 at Home Depot. I used 3 ea 4" galvinized angle iron that has holes/slots drilled the length of the angle iron and 6 each 4" strap/standard hinges. I cut 1 piece in half and used that between the bottom of the rt rear jack and the frame going forward, and the other 2 pieces of angle iron going from bottom pad of rear jack to top of jack mount on the other side going accross the back of the trl. I used the hindges to attach the angle iron to the jacks and frame at both ends of both bars, then 1/2" bolts and nuts to bolt the bars together 2 for each bar. They work great to stop the shimmy shake of the trl, that and the wheel locks.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 01-01-2012, 09:34 PM   #4
I made my own as well, very similar to the Bal Lock bars.
They work very well, but I sure wouldn't pay what the sellers want for them. Including all of the swivel ball-joint ends and tubing, I made mine for less than a hundred bucks.
Old 01-02-2012, 04:57 AM   #5
troyt's Avatar
Would you by chance have pictures? I'm having difficulty visualizing this. I would be very interested to see how you set this up.
2006 Dodge 2500 Crew Cab 5.9L Cummins 4X4 200k mls
2010 Forest River Flagstaff 831QBSS - Equal-i-zer Hitch
2011 HD FatboyLo & 2000 Honda Shadow 1100
Nights Camped 2010 (7), 2011 (15), 2012 (35) 2013 (40) 2014 (22) 2015 (12) 2016 (10) 2017 (?)
troyt is offline   Reply With Quote
Old 01-02-2012, 06:21 PM   #6
Don't call me Junior!!!
X2.. With a pretty please
2012 Tracer Executive 2600RLS
2011 Chevy Tahoe HD Towing Pkg
BubbaTex is offline   Reply With Quote
Old 01-02-2012, 10:27 PM   #7
sherdep's Avatar
x3 with sugar on top
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 01-03-2012, 06:08 AM   #8
lindy's Avatar
Trl buried under snow right now that and I'm not techno at all and just haven't been able to post pics yet.Basicle though I have two stabilizing bars one going diagonally left to right at the rear jacks one end mounted on the jack pad and the other end mounted at the jack mount. The 2nd bar runs from the bottom of the rt/hand rear jack diagonally up to the frame where I had a bolting point. Each bars consists of 2 bars that I bolt together in the center. The bars extent as the jacks are lowered thus the need for the bolts.
F.R.O.G. member
