I too made my own for about $54 at Home Depot. I used 3 ea 4" galvinized angle iron that has holes/slots drilled the length of the angle iron and 6 each 4" strap/standard hinges. I cut 1 piece in half and used that between the bottom of the rt rear jack and the frame going forward, and the other 2 pieces of angle iron going from bottom pad of rear jack to top of jack mount on the other side going accross the back of the trl. I used the hindges to attach the angle iron to the jacks and frame at both ends of both bars, then 1/2" bolts and nuts to bolt the bars together 2 for each bar. They work great to stop the shimmy shake of the trl, that and the wheel locks.
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
F.R.O.G. member
