Old 06-04-2015, 07:11 PM   #11
You should really give the Maxxis 8008's a hard look. I am going on 3 years on mine. I moved up to a E from the factory D's. Just a bit more cushion for peace of mind. Good luck, John
shadows4 is online now   Reply With Quote
Old 06-04-2015, 07:19 PM   #12
Blog: RVroadtripper.com
hbillsmith's Avatar
I looked at the new Carlisle 16" F rated. They certainly look beefier and the largest 2 do indeed have ST in their model number. I see they have recommended PSI of 95 vs. my Maxxis' 80 psi. But I could not find anywhere that Carlisle supports 87mph. No matter, its only 75 mph on very smooth freeways that would come into play. Unless you travel the Austin Texas east side toll way where the limit is 85mph.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 06-04-2015, 07:43 PM   #13
Send a message via MSN to Tiggerdad
Originally Posted by ddphillips52 View Post
I have a 295RST with 245/70R16 Firestone TransForce HT's. They fit just fine with the lift from the Correct Trax I had installed.
Exact same tire, same size and same rims I have.
OP-If you buy new rims they should be s "Zero Offset" That puts the load between the bearings. Trailertire and wheels have good pricing on rims and will sell you any brand. Good company to deal with and good prices.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 06-04-2015, 08:02 PM   #14
dannyabear's Avatar
Originally Posted by robbdrell View Post
Anyone have any thoughts on going from a 14 to 15 on my Rockwood 2608? When I look at the tires, I can't believe they put 14's on a 29 ft trailer. Want to go with Maxxis after this yrs trip.
Hankook RA08 in 195R14 is exact size as ST205. But it is load range D, 8 ply, 99 mph speed rated and carries 2100# @65psi. Great tires but I have only had them for 8 months and only a few thousand miles, but I have a lot more piece of mind now..
Busdepot.com 4 shipped to your house for $500.00
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 06-05-2015, 07:29 AM   #15
Make sure the new rims can take any higher tire pressure. Tires discussed are in 90/100 lbs range and check the number of lugs. If you go to 8 lugs to need to change the hubs.
btritschler1437 is offline   Reply With Quote
Old 06-05-2015, 08:53 AM   #16
Claude002's Avatar
wheel and tires
My original tires had to be 65PSI if I change to Carlisle LRE They require 80 PSI will my wheel accept this new pressure?
Have a Crusader 290RLT
Claude002 is offline   Reply With Quote
Old 06-05-2015, 09:39 AM   #17
Crawl under RV and look at back of the rim, it will have max psi stamped on back of rim.
Old 06-05-2015, 09:53 AM   #18
Claude002's Avatar
Will have a look ---thanks
Old 06-05-2015, 10:49 AM   #19
Claude002's Avatar
To btritschler1437--TOOK THE WHEEL OFF this is the results--MAX LOAD 2830 LBS/668 15X6.0 J/ET 0/T-DOT/NO 1/12!!!!!/C/M/L/T06---NO where PSI rating is mentioned---WHAT I WANT TO BUY IS THE 10P FROM CARLISLE # 225/75R15 LRE--5151411--Do not want to put more weight or go faster but want to be over protective--only a few bucks more---can you clarify--thanks
Old 06-05-2015, 11:21 AM   #20
Claude002: I am doing the exact same thing as you as I have a 290 RLT and am looking to upgrade. I have also been looking at the Maxxis tires, is there any particular reason you are going with the Carlisle tire? The Carlisle also look to be a very good tire. Keep me posted on your rim issue, I wiull be looking at my rims tomorrow.
brireey is offline   Reply With Quote
wheel
