Old 06-03-2015, 11:02 AM   #1
looking to go to larger wheels
I am looking to go from a 15 " wheel to a 16" wheel in order to put on better tires, especially with all of the controversy and problems on the Power King tires made in China that are called China Bombs. It seems that my existing 15" rims will only allow an ST tire to be mounted and most or all ST tires are made in China. Does anyone know if 16" rims would fit on a Crusader 290 RLT or should I even attempt to do this.
We are planning on retiring this summer and traveling and I want to make sure I have good quality tires. Any recommendations on what would be a good tire to purchase and what rating I should be getting to upgrade? I presently have Power King ST 225/75R 15 tires. Any help would be appreciated
brireey is offline   Reply With Quote
Old 06-03-2015, 11:15 AM   #2
If you could find a 225/70-16 tire that is almost the same size, diameter, as the tires you have.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-03-2015, 03:45 PM   #3
My 2014 290rlt came with the touring package and has 16 inch tires so yes they can be used.
I don't know if you have to do anything special (I seem to recall someone saying something about a rubber spacer in the axle mount ) but I assure you a 290rlt can have 16 inch tires.
Robert
rscconrad is offline   Reply With Quote
Old 06-03-2015, 05:12 PM   #4
From my reading of tire threads, this is what I gather....
16" tires give you more tire options and you can purchase tires with a higher load/weight capability. However, it is common for the trailer manufactures to put on axles that don't have extra capacity -- frequently they are sized to the trailer weight with no extra wiggle room and the tires are sized to the trailer weight with no extra wiggle room.
Prime Time does sell the 16" upgrade on the Crusader trailers. I wish I would have done that to have more tire options.
Now, having said all of that.... I researched this to death because I'm concerned as well about the tires that PT used.
The most recommended tires on the forums in 15" are the Maxxis M8008. Down side, speed limited to 65 pmh.
The ones I will probably try when it comes time to change tires will be the Carlisle Radial Trail RH. They have a new design that addresses the problems they had a few years ago. Also, they have designed and tested this ST tire for a speed rating up to 87 mph (depending on the size you buy). It's the only ST tire I've come across that has a speed rating above 65. People are starting to make positive comments about the new design (about 3 years old now?).
If you want to go with larger rims and go to an LT tire, the ones that get the most recommendations are the Goodyear G614, the Michelin RIBS, and then to a lesser extent the Sailun S637 and Bridgestone Duravis R250. (I think those are all LT.) I've read that the G614 will provide some warranty coverage for RV repair if it fails and damages the RV (you must keep the tire and ship it to Goodyear).
2014 Crusader 296BHS
2015 GMC 2500HD Denali
kohai is offline   Reply With Quote
Old 06-03-2015, 06:30 PM   #5
Thank you for all the feedback, I will definitely look at the Carlisle tires. I have also heard good feedback on the Goodyears.
Old 06-04-2015, 03:40 PM   #6
Rodgers's Avatar
I did that to a 1999 Sierra 15s to 16s rims just make sure you will have enough clearance between wheel well and top of the tire. Mine was was very close.
Rodgers is offline   Reply With Quote
Old 06-04-2015, 03:52 PM   #7
Blog: RVroadtripper.com
hbillsmith's Avatar
All ST tires including Maxxis 8008 are limited to 65mph.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 06-04-2015, 03:53 PM   #8
ddphillips52's Avatar
I have a 295RST with 245/70R16 Firestone TransForce HT's. They fit just fine with the lift from the Correct Trax I had installed.
Dennis, Linda, and Scout the Dog
2015 Mesa Ridge 347 RES
Husky 16KW with Reese Sidewinder
2013 4WD RAM 3500 Cummins TD SBCC
ddphillips52 is offline   Reply With Quote
Old 06-04-2015, 05:27 PM   #9
Anyone have any thoughts on going from a 14 to 15 on my Rockwood 2608? When I look at the tires, I can't believe they put 14's on a 29 ft trailer. Want to go with Maxxis after this yrs trip.
robbdrell is offline   Reply With Quote
Old 06-04-2015, 05:55 PM   #10
That's no longer the case. The Carlisle radial trail rh are rated up to 87 mph.
wheel
