Old 02-26-2015, 07:20 AM   #1
IlliniJoe's Avatar
Maiden voyage/shakedown
Just returned last night from our 1st trip in our camper that we purchased back in June. Went to the Daytona 500 and back for a total of 2081.9 miles. Issues That I/we found that need addressed.
Camper towed really well with no issues, except that I think I need to tweak the weight distribution.
Toilet flush valve was cracked. When I turned on the pump, it looked like a fountain in the bathroom. I had to disconnect the supply line and plug it so we could still use it with a jug of water.
Grey water tank gives false levels. I know this because the first time I filled the potable water tank (48 gal), after three days, the tank showed that it was full, with the potable water tank showing 2/3 full. The grey tank is 60 gallons and we were taking "Sea showers".
Both the grey water and black water tank valves leak by.
Kitchen slide needs adjusting. Looks like it does not seal completely when in the extended position. There is about a 1-1/2" gap between the slide and the wall, vs no gap on the dining slide.
Diner slide is leaving a black mark on the floor and the underside is wearing.
Replaced the supplied short foam mattress with a full sized 8" queen memory foam mattress prior to departure. What a differance for me.
The awning arms will slide back up to the normal position after the angle adjustment knobs have been tightened. I did get Old Coots awning brackets installed while I was there. So this should make this a moot issue.
Overall though we had a great experience.
Retired Army CW4 - "Waterborne"
2005 Chevy 2500 crew cab with Duramax/Allison
2014 Lacrosse 327RES
Days camped 2014 - 0, 2015 - 24
IlliniJoe is offline   Reply With Quote
Old 02-27-2015, 12:18 AM   #2
Platokidd's Avatar
Have to get that fixed
Always a false read , normal
Not normal, added to the punch list
Yep, need adjustment
see this as it may help http://www.forestriverforums.com/forums/f210/slide-out-underside-wearing-45789-46.html#post786145
Slide-slickers stop mine from leaving black marks.
Brackets and poles work good to hold the awning
How was the race?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 02-27-2015, 12:39 AM   #3
asquared's Avatar
I agree with platokidd except 2/3 full on black tank after 3 days even with navy showers isn't uncommon. You need to do a more controlled test on that to see how the sensor functions.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 02-27-2015, 12:49 AM   #4
Platokidd's Avatar
Agree , Im sure the op had plenty of room in his grey tank.
Seasonal
Old 02-27-2015, 06:05 AM   #5
IlliniJoe's Avatar
Plato,
The race was great. We got there on the 12th when the infield opened and left on the 23rd. Spent two nights at the campground at Fort Rucker, Al. If you are a Military I.D. Holder, I highly recommend it. The only bad thing about the race though was my neighbor on the infield, was a fellow Ketuckian that also happened to be the 2014 Kansas City BBQ Society Champion. now I'm scared to weigh myself after having to smell the smoke from the smokers and eat all of that sinful smokey candy.
Old 02-27-2015, 07:45 AM   #6
I believe he said (Gray Tank 2/3 full) after 3 days. Youroo!! I agree on the (Fort Rucker C/G also)!
Old 02-28-2015, 12:09 AM   #7
asquared's Avatar
Yup that's what I meant to type. Grey not black, that's what I get for late night posting.
2014 Sabre 34REQS-6
