Old 07-10-2014, 06:48 PM   #1
Main slide out
Hello I have a tracer 3200bht the kitchen and bunk slide outs run perfect smooth but the main dinette and couch slides jumps a little or hops when coming in or out. I know this slide is a different setup with the cables and some sort of chain drive but is this normal??
2010 Dodge Ram 1500 + Prime Time Tracer 3200BHT
Dexter82 is offline   Reply With Quote
Old 07-10-2014, 08:43 PM   #2
Hi, I have a tracer 3150BHD. I recently had an issue with a cable coming off my dinette and couch slide.
I'm not a mechanic by any means but what I learned in fixing this is fixing a cable is not that hard.
Try to watch your slide chain and cables as someone else extends and retracts the may need adjusting.
This may help//
good luck!
Tracer 3150 BHD
Silverado 1500 Crew
2damcold is offline   Reply With Quote
Old 07-11-2014, 08:33 AM   #3
Platokidd's Avatar
I had a tracer 2670
Just some things I found with my cable slide out.
1. The dinette was screwed through the floor and the screws went to the outside. The screws would catch on the wear bar and gouge it up. Check under the slide outside for screws sticking though.
2. The wood floor would catch on the wear bar when retracting the slide. This made a popping sound and splintered of the wood of the floor. Lift the carpet and look to see if wood is flaking or chipping off.
3. I had my tracer for 10 months and had my cables adjusted a few times when in for service to prevent / stop the wood sub floor from catching the wear bar.
Never did stop the wood from chipping off. But my dealer said the cables need to be adjusted often.
4 It could just be the wipers and seals are popping when opening and closing the slide. This would be normal.
Lets us know how it works out.
Next year is here - GO CUBS- 4 more WINS to go
2014 LaCrosse 323RST-TE-C
2009 CHEVY 2500HD Silverado Z71
2016- 89 nights of camping
Old 07-22-2014, 09:21 AM   #4
Well after much ado...I replaced the switch, reattached a cable that had come off the slide pull system, and all seemed well in the driveway.
Once at the joy.
Brought the camper home AGAIN and after great difficulty got the slide extended to look at the motor only to discover that two wires had melted their insulation when the motor overheated and were now making contact.
I fixed this and so far have had no further issues.
I am installing an inline fuse (40 amp) to hopefully negate this issue in the future and perhaps prevent a fire. I say this because the wires heated to the point that the switch became hot. To me not a safe thing to happen.
Tracer 3150 BHD
Silverado 1500 Crew
Old 07-23-2014, 10:10 AM   #5
RollingDownTheHighway's Avatar
I have the same model and mine does when it starts and then slides in/out smooth. Our back room slide did it the first few times we used it and now its slides smooth.
2013 Prime Time Tracer 3200BHT
2016 GMC Crew Cab Duramax All Terrain
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
slide, slide out
