Old 10-27-2011, 08:24 PM   #21
M109Rrider I use a bottle jack also. Just a thought, I welded a piece of SCH 80 pipe that i cut in half so it will wrap around the bottom of my axle, works great and pretty soild when lifted up. I got the idea when i had one shift once without a tire. A bit scary
2011 Crusader 298 BHD
2008 Ford F-250 4x4 CC W/ V-10
Family Guy is offline   Reply With Quote
Old 10-28-2011, 08:30 AM   #22
sfrye5853's Avatar
How does the half of the pipe affix to the top of the bottle jack? I was going to use a block of wood, but this might be a better solution.
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 10-28-2011, 08:37 AM   #23
grhodes50's Avatar
.......I welded a piece of SCH 80 pipe that i cut in half so it will wrap around the bottom of my axle, works great and pretty soild when lifted up.......
As I understood it, he welded the pipe that he cut in half to the bottle jack.
Old 10-28-2011, 08:48 AM   #24
sfrye5853's Avatar
I was thinking Grey PVC SCH 80 pipe... Don't know how you would weld PVC to a bottle jack. That's why I was seeking clarification. Assuming it was metal SCH 80 would make sense.
2012 Tracer 3150BHD
Old 10-28-2011, 09:39 AM   #25
M109Rrider's Avatar
I use my big floor jack at home and haven't needed to use the bottle jack along side the road yet. I'll use a block of wood if i can or jack on a u bolt if the wood doesn't work. I figure when it happens i'll do what I gotta do
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
