Old 10-14-2018, 04:08 PM   #1
SecretSquirrel's Avatar
Missing fresh water tank overflow hose?
Has anyone else noticed if their Primetime has an overflow hose for the fresh water tank or not? I don't see one one mine. Are they expecting it to overflow via the vent next to the fill hole.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is offline   Reply With Quote
Old 10-14-2018, 04:34 PM   #2
KeithInUpstateNY's Avatar
My Avenger only overflows via the vent adjacent to the fill tube. My Keystone Bullet was the same way.
KeithInUpstateNY is offline   Reply With Quote
Old 10-14-2018, 04:43 PM   #3
Denver To Yuma In 90 Days
A lot of the new TT's and 5'vers still have the vent hole right next to the fresh water tank fill, but they are no longer used these days very much.
If you have a 5'ver you can look directly at the back side if that inlet and you can see if it indeed has a vent tube or not.
Mine doesn't...
Plus, the overflow tubes on the bottom of the trailer will work as the same thing.
But if you buy a filler tube ($3 at Camping World)...you won't have an issue filling your fresh water tank.
JohnD10 is offline   Reply With Quote
fresh water, tank, water, water tank
