Guys,
OK, we have some other questions on our rig. I have tried to contact PT without any Luck........ so here are our problems (well not really problems just No Answers!!!)
Does anyone know where the Galley tank drain into?? We have a black & gray valve, but No galley. Also there are 3 pet cocks - one marked Low Point Drain (which I know) the other marked fresh water drain (which I also know) but the the other is on a Red line(coming out of the bottom of the floor) Not Marked, so any ideas on this one???
I am wanting to change out the blubs through out the house to LED only I don't know the watts of the 921's that are in there now??
Also here is a Real Good One - the radio/DVD player keeps coming on by itself. Now I have tried everything I know to do, looked on the remote to make sure it set to Off. However it Only has On/Standby on the unit so any help with this would be Great?
Thanks ahead of time for the Help.............
Phil & Linda and our two four legged babies - Cricket & Brutus
2016 F350 Super Duty
2017 Heartland Big Country 3560ss 5th Wheel
There should be another valve pull handle for the galley grey up under the skirting in front of the wheels. Same side as the other pulls. It goes through the frame. The red drain cock is the hot water low point drain. Can't help with the bulbs but the radio coming on May be caused by the fire place remote. If you have one remove batteries and see if the problem stops.
2014 295rst TE Champagne
09 GMC 2500HD D/A
2012 Crusader 290RLT 2012 Silverado 2500 Duramax (175,000 mi)
Camping:
2012: 4564 mi 31 days - 2013: 6277 mi 38 days
2014: 5146 mi 38 days - 2015: 1200 mi 9 days
2016: 342 mi 2 days - 2017: 2734 mi 22 days
OK, thanks for the help. We will check tomorrow right now in the middle of Bad rain storm.
As to radio we don't have the fire place???? Will keep checking.....
Is your radio the Jenson Radio/CD Player? You might have an Alarm set.
To set the alarm,
press and hold the ALARM SET button (9a). The number representing the hours will flash. Rotate the TUN/TRK control (12) to adjust the hour. Press ALARM SET again briefly and the number representing the minutes will flash. Rotate the TUN/TRK control toadjust the minutes.
Press and hold the ALARM SET button again to store the alarm time.Once a time is set, press ALARM ON/OFF (9b) to turn the alarm function on or off.
Camping:
Hey Guy,
We do have a Jenson, however it is in the bedroom and not the one with the problem. The one in the living room is a RCA radio/dvd player???but thanks for the info..
To set the alarm,
You should have three pull handles. I have a 325res and I was missing a handle. Should be universal handle just screw new one on. Make sure you put a little lock tight on it or it will come off again.
Sent from my SCH-I545 using Forest River Forums mobile app
OK,
Thanks for All the Help. I have found the valve, however I am still looking for the watt of the lights and have just decided to stop worrying about the radio.....
Phil
check out these mods that have been completed to enhance the 270, you will get it fixed, I have some phone numbers, plan to attend the FROG Rally in Goshen, IN next August, there you will get all your problems solved, by the way, where did you buy this 270RET, ours was purchased in Marietta, GA>
Originally Posted by plshilo
Guys,
Here are a few photo's of a few things we have mod'ed, we have several more items that I would like to share with you: Just let me know.
LKicklight
Sent you a private email: On the LEDs, that is pretty easy has we have changed out everyone in and outside of the coach: You want a WEDGE 194 type bulb, we purchased like 40 of the wafer type LED's, not as bright as the Filiment Bulbs, but are a lot kooler. Can send you a picture, all were purchased on Ebay: All the running lights have also been changed out too, as well as the tail-brake-turn signals. Also have installed 300 Bright White LED Ribbon lights in the Cargo Compartment and Front Battery Compartment, really makes one heck of a difference: Have Photos also:
Step lights inside and outside on one switch, similar to a Sanibel:
Hey LKicklight,
Sent you pm on the other stuff...... please send the ebay info on the lights, we are going to Tampa tomorrow for the Super Show and were going to the find the rest of the stuff we need.
Phil
Please find the Forest River Booth, ask for Bob and Cindy Byrnes, he is in charge of the FROG Rally Group. Also, what are you looking for as all my stuff came from Ebay...let me know what you want and looking for, would be glad to help you get what you need: Sent you my email and phone number in a private message: 6:19 PM toady
Hey LKicklight,
Phil
Just curios if anyone knows how many 270RET’s were produced before the floor plan was discontinued?
I found this last week for the bumper. I have not tried them yet. Sold with or with out tether. I purchased the tethered ones. http://www.amazon.com/Camco-40324-In...Cap+with+Saver
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
I found this last week for the bumper. I have not tried them yet. Sold with or with out tether. I purchased the tethered ones. Amazon.com: Camco 40324 No Insect RV Bumper Cap with Saver: Automotive
Hey
I am not sure how many were made, but maybe someone will come up with a number. As to the cover can't make a comment as I have the pvc pipe attached to our bumper.
Phil
Hey
Phil
E-mailed Primetime R.V. with the question, how many 270RET’s were produced before the floor plan was discontinued? The response was …………..“300 units were produced and sold”.
