Old 06-22-2015, 03:41 PM   #1
Need new shocks on my '12 Sanibel 3500
I've got about 20,000 miles on my '12 Sanibel 3500 and it needs new shocks. I've found regular replacements-Lippert heavy duty shocks- but they don't seem to be all that heavy duty to me. Has anyone found a heavier duty shock than Lippert installed at the factory??
Ken
2012 Sanibel 3500
11 GMC 3500 dually, Duramax/auto
kdanie is offline   Reply With Quote
Old 06-22-2015, 04:03 PM   #2
clr
Lippert makes the frame for the Sanibel as well as many other models. So I guess that they put their own shocks on their frames. I had this problem with my old 5th wheel and was able to remove one shock that it into NAPA and they were able to cross the old shock to many models made by others.
clr is offline   Reply With Quote
Old 06-27-2015, 07:01 PM   #3
Send a message via MSN to Tiggerdad
Take one to NAPA or any other parts store. They can cross to a Monroe which is better and only costs a few dollars more. I think you will find that the old shocks are bent, frozen up or have no action. That's what happened to the ones on previous rig after only a few thousand miles.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 06-27-2015, 09:37 PM   #4
Thanks, these are just worn out, I'll check with NAPA and see what they can do.
ken
2012 Sanibel 3500
Old 06-30-2015, 08:44 AM   #5
BBBlue's Avatar
ken
I would be interested in hearing what you found at NAPA.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
Old 06-30-2015, 08:51 AM   #6
You can measure the compressed length and extended length of your old shock and find a Monroe replacement.
File Type: pdf Shock absorber Mounting Length Sheet.pdf (310.4 KB, 30 views)
Old 06-30-2015, 12:55 PM   #7
I've been disappointed with parts counter people for years, if they don't have a make/model/year to put in their computer they can't find anything BUT I got them to give me their book and I found only one shock with the same specs and it was a basic passenger car shock #5157-NAPA brand made by Monroe. I don't think it will be enough dampening on a #15000 5th wheel... Hopefully my shocks from Lippert will arrive today so I can get them on tomorrow morning early before it hits 100*.
If the shocks were just mounted with eyes on each end better replacements would be easy to find.
I suppose I'll get another set on the way when i get about 10,000 miles on these.
ken
2012 Sanibel 3500
Old 06-30-2015, 01:00 PM   #8
ken
I sincerely doubt that Lippert shocks are as good as Monroe and the valving will probably be the same. IIRC, they are probably 65/45 valving. IMO, I would go with Monroe as they probably sell to Lippert and have been making shocks longer than Lippert has been in existence.
Old 06-30-2015, 01:15 PM   #9
TURBS's Avatar
There should have been a name and part number stamped on the bottom of the shock.
Lippert likely doesn't even make there own shock as suggested.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 06-30-2015, 01:19 PM   #10
TURBS's Avatar
Like such.
TURBS
2011 32bhok Sabre
3500, 500, sanibel
