Old 03-08-2013, 09:14 AM   #1
New to Forest River
New baggage doors - Trim
I also posted this over at RV.NET and got a few ideas:
had the RV dealer add a couple of extra outside baggage doors to my new trailer. They give me access to under the dinette benches, from the outside. They look great and fit perfect. The issue is that the doors don't have wide flanges on the frame, so the freshly cut wall (inner panel and styrofoam insulation) are exposed all around the opening. I'm concerned about water and/or bugs getting in and also about the bottom edge of the opening getting beat up. The RV Service Manager says the door source does not have a trim kit for the door, so maybe they could put some undercoating or something similar on the exposed areas to protect them. That would help, but I don't love it.
RV.NET Link: RV.Net Open Roads Forum: Travel Trailers: New Baggage Doors - not trimmed
Pictures:
Mike & Tracy Boyd
2013 LaCrosse 318BHS Touring Edition - Forest River - Prime Time
2006 Silverado 2500HD 4x4 Crewcab SB DMax/Allison
Graduated from 1999 Dodge Ram Extended 2wd 5.9L &
2005 Prowler Lynx Ultralite 29BHS
Mikedboyd is offline   Reply With Quote
Old 03-20-2013, 12:03 AM   #2
New to Forest River
OK - I have the doors 'trimmed'. it turned out very good. The basics are a nearly 2" waterproofing foil tape covering the 'raw' area, with some 'L' channel 1/8" aluminum bar covering the bottom and side flat areas. Pictures below:
Basic issue - good new door, not trimmed, delicate material left exposed:
Basic fix is to take some Waterproofing Foil tape, a little wider than area to cover (a little overlap) goes on with a very aggressive adhesive.
After putting down the foil, all the way around the hole, you bring out the big metal (1/8" L channel aluminum bar.
Mike & Tracy Boyd
Old 03-20-2013, 12:10 AM   #3
New to Forest River
Foil gets laid down
Aluminum bar gets epoxied down to the foil
This shows the bottom and side aluminum bar epoxied in place. just the corners are exposed and they have the waterproofing foil. I'm pretty happy with the result.
Mike & Tracy Boyd
Old 03-20-2013, 05:33 AM   #4
spierce617's Avatar
Wow! Nice looking job.
1999 Chevrolet Suburban 5.7L V8
2005 Cherokee Lite 28A
spierce617 is offline   Reply With Quote
