Old 06-01-2013, 04:07 PM   #41
Roll's Avatar
Originally Posted by RV Guy View Post
Hmmm - pump? Do you have a Crusader? I'm confused.
PTM
No, not a Crusader. But this isn't about the LCI hydraulic leveling system? I had been told it was.
I have a 2011 Coachmen Encounter with the LCI system.
Roll
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 06-01-2013, 05:42 PM   #42
Toy-aholic
Originally Posted by rhollar View Post
Well we just pulled the 325RES home yesterday and backed it into the barn and started to set everything up. I thought the levelong sytem worked but today I noticed it looked as though the right side was lower than the left. Still reading everything but can you extend the right side by itself to level rig. I put a level on it and it is full bubble off. Thanks
yes you can, use the left or right buttons
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 06-01-2013, 06:02 PM   #43
i did get it level, then shut it off. I hope I did it right. If not i guess I'll start over. Thanks for all the help. Sent RV guy a PM too.
2013 Crusader 325RES
2006 Chevy 2500 CC/SB Duramax/Ally 4X4
rhollar is offline   Reply With Quote
Old 06-02-2013, 12:18 PM   #44
VinceU's Avatar
Roll
Roll,
Try the IRv2 forum, sister to this one. Go to the Monaco section search for hydraulic pump thread you'll find a step by step process to repair the pump. Let leak it will cook the motor!
Very eazy fix.......
Old 06-06-2013, 02:06 PM   #45
Originally Posted by jwhitacre View Post
We just picked up our new 290RLT TE a few weeks ago. We have been putting it through the tests and so far we love it!
My main question so far is with the electronic auto leveling system. Stability overall has been a question mark for me even with a king pin stabilizer.
First of all, I read on another post that the landing gear are designed to have a slight outward pitch for increased stability. All four of my landing gear appear to have a very slight inward pitch. Is there a chance that my gear where installed on the wrong sides and if so, is there a way for me to check/verify if this is the case?
Second. When following the "Auto Level" procedure on two occasions, the procedure completed successfully but it raised all four wheels completely off the ground. At first I was not sure if this was normal but I read in the manual that the wheels should not be off the ground. I put blocks under the wheels and manually lowered the rear then front until the wheels where on the ground and the front to back was level. Just not sure why the "Auto Level" would complete in a condition the manual says is unsafe.
Any help would be appreciated. Thanks.
We have had the same problem but have solved it as follows:
When I take the Crusader off of the truck the nose is in the up position. Thus if we let the front jacks down by pulling the pin they drop over 15-16 holes. When this happens the front jacks become static at a level that is too high for the back jacks to level with without pulling the tires off the ground.
Now when we take the trailer off the truck we let out 10-12 holes in the front jacks. Then use the drop front jacks option to allow the electronic part of the jack to run down far enough that it can level the unit without lifting the wheels off the ground.
Hope this helps
'12 Dodge 3500
'13 Crusader 295rst
rmw408 is offline   Reply With Quote
Old 06-06-2013, 03:06 PM   #46
zs325RES's Avatar
Hope this helps
Great suggestion. This way the jacks are more stable too.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 06-06-2013, 03:45 PM   #47
We use the same approach. Drop the front 9 holes, drop the back 3-5 holes. However I don't go straight to the ground, I use 4x4 wood blocks to rest the legs on.
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 06-07-2013, 02:25 PM   #48
If you use blocks for the legs, won't that confuse the leveling system unless the tires are on the same height blocks?
jwhitacre is offline   Reply With Quote
Old 06-07-2013, 02:57 PM   #49
Toy-aholic
all it wants to do is level...doesn't care what height
Old 06-07-2013, 07:27 PM   #50
No works fine as described.
