Old 06-03-2014, 08:07 AM   #11
Originally Posted by heavynlori View Post
Isnt it supposed to auto level on its own?? You say you hit this and that button to level this and that but Auto Level should do it for you...,,whole idea of the system 👍
If you are referring to my post, my leveling system is a Ground Control and it is not "automatic leveling". I bring each front jack only in contact with the ground independently and then raise them simultaniously. Then do the same with the side. gljurzyk was speaking of the automatic system he has coming.
EYEMAN is offline   Reply With Quote
Old 06-03-2014, 08:07 AM   #12
irishrv's Avatar
Not all the ground control systems (3 or 4 versions now) have auto level. Just like not all have a remote control.
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 06-03-2014, 09:10 AM   #13
heavynlori's Avatar
My bad...😉. Thought they all had the auto function - guess I would not want it if it did not...kinda half the job at full price but do wish ours had the remote too! We just hit the auto level and go to hooking up water and electric while it does its thing. We are also on a seasonal spot so we do not have to use it on a regular basis.
heavynlori is offline   Reply With Quote
Old 06-03-2014, 01:16 PM   #14
I didn't find this set to be "at full price". At $2400 I found them to be over one K less than the auto leveling and it has a wired and wireless remote.
Old 06-03-2014, 06:00 PM   #15
Witch Doctor's Avatar
That is really a good deal. CW would have sold it for 2400.00 and install for 149.00. The board as stated to make it auto is 1000.00 more. Lippard will give you the 3.0 with auto and remote for installed for 3200 00 Dollars installed at the factory. The difference between the Rico Titian and the 3.0 is that the motors 3 x's faster then Rico and self leveling with memory of the hook up, but that will also work with the Rico Titian.( memory only) Rico is also a lippert com. At least under there umbrella. I have researched this to hell and back.......Both are great system just depends what you want......
Coachmen M/H
Concord
2018 / 300 DSC
leveling
