Old 05-23-2014, 08:31 AM   #1
New Leveling System
In the process of installing a new Ground Control leveling system on my 27' Avenger. It is a remote electric system by Rieco Titan. It appears to be very high quality and heavy duty(20,000 lb. capacity). Anyone have or had one of these?
EYEMAN is offline   Reply With Quote
Old 05-23-2014, 08:54 AM   #2
irishrv's Avatar
Pretty similar to the lippert system on the crusaders (I believe lippert now owns rieco titan) although ours doesn't have remote control, the panel is in the basement. Another benifit is it looks like the rear jacks are the gen3 system meaning no pins to pull to drop the back legs - better for sure. Should be a good system for your rig. The achilles heel with all these auto levellers appears to be the computer box. We had ours give a right rear error on the last outing and wouldn't work for back jacks. Got home and it worked fine. Overall I'm glad I have them but there is a learning curve for sure.
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 05-23-2014, 09:04 AM   #3
cronek28's Avatar
I have a auto level question while on the topic. Those of you that have it, is your camper pretty solid when setup? 6 point helps? I'm guessing. I don't know if I can afford or justify a auto level but it is sure something I would brag and brag and brag about!!! I was camping with a friend who has it on his Raptor toy hauler last weekend and I was amazing how solid the camper felt and I was wondering if it was from the auto level or if the toy hauler was just better built than mine
2013 Sabre Silhouette 320FQDS
2010 Puma 26FBSS (TT sold)
2007 2500HD Silverado Classic Crew Cab 6.5 box
"Duramax"
B&W companion slider
cronek28 is offline   Reply With Quote
Old 05-23-2014, 07:45 PM   #4
irishrv's Avatar
Mine is pretty solid with 4 point but still considering either rear electric stabalizers or the winfield stabalizers to get it the rest of the way.
09 GMC 2500HD D/A
Old 05-23-2014, 07:59 PM   #5
Witch Doctor's Avatar
I'm getting the 4 point ground system 3 with the remote. This system counts revolutions of the motor. I also looked at the OP system. It is not auto level without adding a new board for $1000.00 extra bucks. It's also the old system that is like 3x's slower and you do the leveling. My unit is 31' long and Leppard said 4 point and leave the electric back stabilizers on. making it a 6 point system. At leppards factory installed with elephant pads and remote $3200.00 AUTO LEVEL. That's a Goshen price. My install date is August 5th. Can't wait!!!
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 06-02-2014, 01:27 PM   #6
Got the Ground Control system mounted. Spent the week in a rv park in Pigeon Forge Tn., which is close to where we live. The Ground Control system worked great. After blocking the wheels, we placed my wife Ipad on the floor of the trailer using a clineometer app which is a bubble level. (1)Raised the front jacks simultaniously as the need indicated on the Ipad. (2) When level lengthwise I lowered both rear jack only enough to stabilize. (3) Level indicated right side low, so I raised the right front and right back jacks at the same time. Stepped up into a rock solid trailer and made a cup of coffee. The key is to never raise one jack indipendantly except have it meet the ground simultaniously with the others. By the way, I did not remove the rear sissor jacks for they can give me a six point system if desired.
Old 06-02-2014, 05:31 PM   #7
That sounds great, glad it worked for you. can't wait to hit the that remote to auto and just watch it do it's thing. After that just lower the rear stabs. and I'm Done...
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-03-2014, 03:49 AM   #8
My only question to you is. Are you afraid of twisting these lite weight frames, that's why you will do 2 at a time? .........
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-03-2014, 07:31 AM   #9
Instructions and all the information I have read states that you should never jack a trailer at a single point. It stands to reason that it would put strain on any frame regardless of the construction. I think you will find that your auto leveling system will not be automaticly lifting a single corner for the same reason. I wouldn't even consider jacking the corner of my truck.
Old 06-03-2014, 07:57 AM   #10
heavynlori's Avatar
Isnt it supposed to auto level on its own?? You say you hit this and that button to level this and that but Auto Level should do it for you...,,whole idea of the system 👍
heavynlori is online now   Reply With Quote
leveling
