Old 07-20-2015, 07:54 AM   #21
Does your 252 have the covered bottom? If so when your tanks are full does it bulge underneath? I took mine out for the first time this weekend and noticed it. Other than that everything seemed to be smooth.
Thewaterguy is offline   Reply With Quote
Old 07-20-2015, 06:12 PM   #22
Yes I have the covered bottom it sags a little, but haven't noticed any difference when the tanks are full. Be careful when towing on uneven terrain the sewer drain is really low.
hurld is offline   Reply With Quote
Old 07-20-2015, 06:20 PM   #23
Thanks. I don't see any water dripping or wet spots. I have heard of some people's drains not attached right. Just being paranoid I guess.
Old 07-20-2015, 06:27 PM   #24
I hear you on paranoid Hey if you get time could you take a picture of your rear most roller under your slide. Mine has a wire in wire loom pinched under it. I'm going to relocate it myself just wondered where the factory hole should have been. In front or behind the roller. Here's a pic of mine. Thanks!
Old 07-20-2015, 06:29 PM   #25
Old 07-20-2015, 07:38 PM   #26
I don't have a hole in my slide. I took this with the slide in. The wires go in a hole in the floor. Which roller is it in yours?
ID:	83527   Click image for larger version
Old 07-20-2015, 07:39 PM   #27
Here is pic of rear roller
Old 07-21-2015, 01:42 PM   #28
Thanks for the pics, but now I'm more confused. The black wire loom in your 1st two photos runs up threw the bottom of my slide & can be seen if I remove the bottom drawer on the left if facing the couch. The wire is then run in a hidden chase in the pantry cabinet. I think the wires feed the light over the couch, but I'm not sure. I'm very curious how yours is routed. I can't see a way for them to run the wire without drilling a hole in the slide bottom. My guess is your wire is hidden behind the roller in your last photo.
Old 07-21-2015, 01:57 PM   #29
Let me see if I can figure it out. I can try and look behind the drawers and see what I can find.
Old 07-21-2015, 06:07 PM   #30
This picture of the front left corner of the slide. The spot the wire goes in to doesn't go outside of the camper when extended.
