Old 12-16-2011, 09:44 AM   #1
New Wheels and Tires, with pictures!
While going through my hub debacle, I realized how lightweight the tires looked and felt.. And with my upcoming trip to Disney World, and the long drive involved, I just was not comfortable with the current tires.
Well, I bit the bullet and bought new wheels and tires. I had to buy wheels, because I upgraded to a 16" tire/wheel. I am now running LT225/75/16E tires. I also bought the most heavy duty LT, yes, LT tire I could find. I did not want an ST tire ever again, after reading the horror stories and the minimal DOT testing for them.
The wheel is a 16x7 Hi-Spec Black series 06 Aluminum wheel rated for 3200lbs and 85psi. The Bridgestone R250, is a severe commercial duty tire. It is beyond heavy duty and the pictures do not do it justice.
Duravis R250: Bridgestone Tires
The difference is unbelievable. I went from a 28lbs tire, to a 51lbs tire (just the tire) The construction of the new tire is amazing, and IMO worth every penny.
Again, I didn't want to spend the money, but my family and our safety is worth it. Changing a tire on the side of I-95 is not my idea of safe, nor fun. Plus I didn't need a hole in the floor or worse, damage to the trailer if they were to come apart.
I have only two pics because it was getting dark. And, I was only able to install 3 of them, because I am waiting on my hub to come in..
See the pics below..
John
ID:	9608   Click image for larger version
2011 Primetime LaCrosse 318BHS Touring Ed
Joined the PT family on 10/2010
2006 Chevrolet 2500HD 4x4 T/V
John
foxhead is offline   Reply With Quote
Old 12-16-2011, 11:32 AM   #2
I'll bet you won't have to worry about those. Looks good. Did your overtall diameter change much?
rkswyo is offline   Reply With Quote
Old 12-16-2011, 11:52 AM   #3
Overall diameter changed 0.9". There were no issues with fitment..
John
John
Old 12-16-2011, 02:49 PM   #4
On my aluminum wheels, the lug nuts are in counterbores. If yours are the same, make sure your lug wrench will fit in the counterbores as I had to grind the O. D. of the lug wrench to make it fit. WEayne
wayne anthony is offline   Reply With Quote
Old 12-16-2011, 03:02 PM   #5
Good thinking. I will check that for sure now..
I did have to use a standard, non-impact socket ...
Thanks!
John
John
Old 12-16-2011, 03:09 PM   #6
Don't call me Junior!!!
Great looking wheels and tires. Now you have me thinking about spending more money. I need your address so I know where to send my wife when she finds out what you have done
2012 Tracer Executive 2600RLS
2011 Chevy Tahoe HD Towing Pkg
BubbaTex is offline   Reply With Quote
Old 12-16-2011, 03:14 PM   #7
Thanks! I have one of my own that is still on the fence about the whole deal....
John
Old 12-16-2011, 06:25 PM   #8
Sgt. Schultz's Avatar
John those look sharp.
Not to be a downer but please be aware that increasing the un-sprung weight at the trailer axles may cause a decrease in braking strength for the trailer - Unsprung mass - Wikipedia, the free encyclopedia - should be of no consequence as long as you adjust your trailer brake controller
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 12-16-2011, 06:31 PM   #9
Thanks. I figured it would be different. My plan is a test run before the trip to adjust for the new wheels/tires.
Thanks sincerely for the advice.
John
John
Old 12-16-2011, 08:05 PM   #10
M109Rrider's Avatar
Those wheels are sharp. Remind me of aftermarket truck wheels. How much did the rubber set you back if you don't mind me asking?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
