Your converter is not working.
What make do you have?
If the converter is not providing greater than 13 volts, your battery will die in 3-4 days. Then you will have "NO DC" at all when plugged in to shore power.
Check the circuit breakers by switching the OFF (all the way off) then back on.
If one is tripped and it says "CONV" you have found your problem.
If the battery is DEAD. YOU MUST REMOVE IT.
The converter WILL NOT charge a dead battery.
It will only charge a LOW battery.
Remove the battery and charge it with a dedicated battery charger. It may take 8-12 hours to charge it. It it won't take a charge it was too badly discharged and will need to be desulphated or replaced.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
