Crusader 290 RLT
Unable to receive SAT signal from the connection outside connector to the inside connector. Discover that the unit has two coaxial cables that run in the wire harness. So the problem was the cable that was hook up to the input outside connector was not connected to the inside wall plate. So with the help of a mirror and flashlight looking behind the hole with the inside wall plate removed I did fine the second coaxial cable with no connector on it. Installed connector on cable and removed the cable that was connected to the inside wall plate and then installed new cable on wall plate. All working fine.
