Old 08-28-2016, 12:13 PM   #1
CMSgt. (Ret) Charlie Brown
CMSgt (Ret) Charlie Brown's Avatar
Odor underneath kitchen sink
We have a 2014 Crusader 330MKS and we are getting an odor coming out of the galley tank. I replaced the cap underneath the sink once about 2 years ago. But I am thinking the p-trap should keep odors from coming back. Thoughts?
CMSgt (Ret) Charlie Brown is offline   Reply With Quote
Old 08-28-2016, 12:57 PM   #2
grhodes50's Avatar
Maybe something in the p-trap itself?
If not, maybe the tank needs cleaning. Might pour some bleach in it, fill it up and let it set for a few hours and then flush out.
Gary & Trish
2016 Nights Camped - 9
Old 08-28-2016, 01:24 PM   #3
Flybob's Avatar
Do you have one of these vents below the kitchen sink? The occasionally fail open.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-28-2016, 01:58 PM   #4
X2. Probably your air admittance valve. All your sinks should have one to allow air behind the draining water since in RV's there are no vented stacks out the roof. Look under your sink on the drain line and you should find one beyond the p-trap. It is probably not closing properly.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-28-2016, 09:37 PM   #5
I do have one of those and replaced it about 2 years ago. Is there any maintenance to it?
Old 08-28-2016, 09:38 PM   #6
Yep. That is what I replaced. Is there any maintenance to it?
Old 08-28-2016, 09:47 PM   #7
Flybob's Avatar
No real maintenance . If you are camping, try tapping it with a screwdriver. If not replace it. Relatively easy.
TST Tire Monitors
2 65W solar panels
Old 08-28-2016, 10:01 PM   #8
Thanks guys.
Old 08-29-2016, 03:32 PM   #9
If you have a length of horizontal waste pipe between the sink drain and the trap, sediment can settle on the pipe and cause an odor. If you can find no other reason for the odor, take it loose and run a rag through it to polish it up.
PenJoe is offline   Reply With Quote
Old 08-29-2016, 06:23 PM   #10
Toy-aholic
x2 on the air admittance valve replacement....also always keep a few gal of water in the galley tank...I found out how bad it can smell when there's little/no water in there.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A FOR SALE
2013 Crusader 335BHS TE FOR SALE
EXGMTech is offline   Reply With Quote
sink
