Old 05-21-2012, 08:40 PM   #1
"Official" word one tire pressure?
Is there any official word on what I should set the tire pressure to on my Tracer 2670BHS with ST205/75R14/C tires?
I've looked through all the manuals and can't find anything. I've also read these forums and find conflicting recommendations.
Dwayne
dapersico is offline   Reply With Quote
Old 05-21-2012, 08:51 PM   #2
Max sidewall pressure, probably 50 psi, filled cold first thing in the morning before the sun hits them. Then only check them first thing in the morning as well.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-21-2012, 08:53 PM   #3
Dave_Monica's Avatar
Set the cold inflation pressure to the maximum pressure noted on the sidewall of the tire...yours should show a maximum pressure of 50 psi.
Dave
Old 05-21-2012, 08:54 PM   #4
shabbona north's Avatar
The correct pressure should be on the trailer, mines on a plaque up on the A frame
shabbona north is offline   Reply With Quote
Old 05-21-2012, 09:11 PM   #5
Wow! Thanks for the quick replies. My tire pressures were actually quite low I kicked them up to 45psi but I think the max was 60psi. I'll kick them all the way up and see how things go. Hoprefully my gas mileage will improve a little bit.
Dwayne
