It is OK to open the Grey tank valves and leave them open but DO NOT leave the black tank (toilet) valve open. The water will run away leaving solids and toilet paper stuck to the bottom of the tank and create HUGE problems.
Also you are going to need to treat the black tank with chemicals, a Blue Streak dispenser or the GEO method to keep the smell at bay. (and another reason to keep the valve closed) Google or search this forum for any of those and you will get days worth of reading.
EDIT:
As a side note, many do not leave the grey tank valves open for a couple of reasons... while you shouldn't put any solids down the kitchen sink, sometimes small particles can accumulate in the grey tank too. A full tank will always help flush those out. Second, many of us use a full/partially full grey tank to 'flush' the sewer hose once the black tank is emptied.
If we are just weekend camping, I don't open my grey valves as we can get by for that amount of time. If we are somewhere longer, I'll open my grey valves (I have two) and then shut them a day before leaving to let the tank build enough liquid to flush the sewer hose.
