Old 08-22-2014, 03:44 PM   #91
Question
Originally Posted by zs325RES View Post
Mine did that once on one side (kitchen). I left it like that for a week with no ill effects. All doors seemed to work normally too which suggests no frame flexing.
Make sure you allow enough adjustability (sp?) for the front landing gear. If you don't run them down a few inches before dropping the legs, the system will force itself to raise the rear to match for level. I've done this since with better results.
Do you think I could/should do it now?
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 08-22-2014, 05:59 PM   #92
zs325RES's Avatar
It won't help unless you hook back up to your TV and get the landing gear corrected
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider, Air Lift bags & Black Bear Performance tune & CAI
zs325RES is offline   Reply With Quote
Old 08-22-2014, 06:04 PM   #93
It's 97 degrees outside I will live with it
Old 08-23-2014, 12:26 PM   #94
rracer5's Avatar
Only if you're prone to nose bleeds from the high altitude!
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-24-2014, 03:14 PM   #95
When the tires come off the ground make sure where the spring attaches to the end of the equalizer (that triangle between the tires) has not flipped. If it has you need to get it corrected or you will break up the rubber in the equalizer. For more info visit the Dexter Axle video on their web site titled E-Z Flex suspension to see how it should look in the correct position.
18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 08-24-2014, 04:01 PM   #96
Just went out and checked they are the way they should be. You got me nervous.
Old 08-25-2014, 08:31 PM   #97
This morning while getting ready to leave the campground I had fun, had problems getting the manual function to work on the front jacks. Ended up doing a retract all then a panic stop once they were below my hitch height and then extended them to the hook up height. I tried to lower rears a little then the fronts a little to get tires back on the ground using the manual setting maybe that's what caused it. I didn't want to lower the rears all the way because of the tires being off the ground.
Old 09-10-2014, 10:22 AM   #98
Got a few questions for any of you 325res owners. First I plan to install a Progressive Industries Hardwired EMS-LCHW50 Surge Guard has anyone done this and if so where did you place it? Second our 325res did not come with slideout covers and it is getting to be pain cleaning the tops of the slides before closing them each time we go camping. Has anyone had them added and what was the cost?
Old 09-10-2014, 10:25 AM   #99
heavynlori's Avatar
Got a few questions for any of you 325res owners. First I plan to install a Progressive Industries Hardwired EMS-LCHW50 Surge Guard has anyone done this and if so where did you place it? Second Are 325res did not come with slideout covers and it is getting to be pain cleaning the tops of the slides before closing them each time we go camping. Has anyone had them added and what was the cost?
We had three toppers and three Maxx Air II vent covers added by dealer at a cost of $2800 - worth every penny - it was all done before we took delivery
heavynlori is online now   Reply With Quote
Old 09-10-2014, 11:53 AM   #100
Purchased three toppers from PPL MotorHomes. www.pplmotorhomes.com These were Carefree of Colorado SOK III part numbers: 26-4963, 26-4985, 26-4993, prices 268.60, 371.45, 419.90 respectively. Shipping 138.50. Cost to install 720.00. Total about 1,900.
crusader
