Old 02-14-2014, 04:14 PM   #21
We put our towel bar above the toilet.
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 02-14-2014, 06:56 PM   #22
Yeah that is probably were I will put one. We have one of the over the door type and used it last weekend but, with the door open the towels kinda get in the way.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 02-18-2014, 05:11 AM   #23
I got a question on the bedroom slide. When closed the bottom part of the slide sticks out just a little more than the top this normal? I noticed there are little rollers on the bottom of the slide is this what could be causing it?
Old 02-18-2014, 05:47 AM   #24
Todouble's Avatar
Mine does that too but I haven't had a problem with it, so maybe it's normal.
Todouble is offline   Reply With Quote
Old 02-18-2014, 09:01 AM   #25
I waited until it got light enough to take a pic.
Old 02-18-2014, 09:04 AM   #26
heavynlori's Avatar
ours is the same way...have not had any issues arise from it
heavynlori is offline   Reply With Quote
Old 02-18-2014, 09:07 AM   #27
I guess it is designed that way. Just seemed strange.
Old 02-18-2014, 09:43 AM   #28
Todouble's Avatar
I thought it would be an issue too. After reading a bunch of post about slides bulging out and slides not adjusted properly I was concerned. But All the other crusaders on my dealers lot looked this way so I assume it's normal.
Old 02-18-2014, 04:19 PM   #29
LKicklight's Avatar
Slide
Ours may stick out a little too, never noticed, have noticed that with the slide open and it rains really hard, the bottom is made in such a way that water does come in. We have had that happen twice, don't know what to do on that one? If you put some kind of tape there, when you close the slide it will come off.
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 02-18-2014, 04:26 PM   #30
Todouble's Avatar
How is that? Where are you seeing water come in? On the bed or carpet???
crusader
