Old 04-28-2014, 12:01 PM   #51
zs325RES's Avatar
Originally Posted by robeachin View Post
....One question we have is the two very large drawers in the kitchen what trick have you found on how to used these. At first we thought great huge drawers but now not sure what to put in them and not get the stuff you need buried in the bottom.
Thanks for any tips or hints
Same here as others have suggested. These two drawers were one reason (there were many others) we liked the 325RES kitchen. Perfect place for all those large pans and bowls. The big pantry was also a big plus for us.
Enjoy your new Crusader!!!
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 04-28-2014, 02:21 PM   #52
Yes it is the two large drawers between the sink and stove. We were able to put all the large pots and pans under the stove. We thought the huge drawer looked great but so far no practical use. I will suggest the large plastic bowls.
Thanks all for the hint on the pantry door. I think we normally do a good job of checking before closing the slides but not so much before opening.
Is everyone just setting the large ottoman on the couch or any tips for this item?
Thanks again
robeachin is offline   Reply With Quote
Old 04-28-2014, 02:24 PM   #53
heavynlori's Avatar
Our new 2014 Crusader 325res observations
You can double stack the dining chairs on one side of table - one chair seat upside down on another then put ottoman in empty space on other side of table
Two chairs also fit the same way in the closet for washer/dryer
We took two of them out and store in house and put the crate for our chocolate lab there - fits perfectly
heavynlori is offline   Reply With Quote
Old 04-28-2014, 02:46 PM   #54
Thanks for the hints.
Heavynlori: We have put two of our chairs in the house also. Will definitely try the ottoman on the floor there instead of on top of the couch.
Old 04-28-2014, 07:34 PM   #55
Thanks again
What we do is after we've tied down the recliners is set the edge of the ottoman on the edge of that slide and when we close the slide it pushes it towards the couch. You have to make sure you rotate the recliners 90 degrees and that they are close to the windows but it works perfect and you don't have to 'rassel that big sucker .
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 04-30-2014, 03:43 PM   #56
2014 327 Lacrosse
Rick, we have the 327, very similar floor plan and during PDI we were told no need to tie down furniture when traveling. Do you have an experience that might change our minds about not doing this
Pipers Family is offline   Reply With Quote
Old 05-01-2014, 04:41 AM   #57
Probably don't need to but, you never know when a fine member of the motoring public is going to do something stupid and cause you to lock em up or swerve.
Old 05-01-2014, 06:54 AM   #58
X-2 secure everything....
grayfox is offline   Reply With Quote
Old 05-01-2014, 07:22 PM   #59
2014 327 Lacrosse
Thanks for advice. Never had so much loose furniture before and with those windows- sure do not want anything flying through them.
Old 05-11-2014, 04:26 PM   #60
rracer5's Avatar
X2 We also put those stick on furniture sliders on the bottom to hepl it slide on the carpet. Sure beats picking that sucker up.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
crusader
