Old 05-08-2013, 11:00 AM   #1
Outdoor kitchen door leaking
I have noticed that I have water stains in the plastic channel on the outdoor kitchen door. The stains are in the left hand lower corner and the metal latches in the frame are rusty. It looks like water builds up enough and rolls over the channel and into the TT. I store the camper with the front raised on a slight hill.The left corner appears to be out of square a little bit compared to the right corner when closed even when level.
How can I tighten this door to stop leakage?
2012 318BHS Touring
Dandy is offline   Reply With Quote
Old 05-08-2013, 01:48 PM   #2
Mine too is doing the same, I took the hinges off the other day and checked the gaskets everything looked good, so I put a little silicone on the gaskets thinking that might help the problem. I checked the other day and still getting a little water on the outside edge but nothing is getting inside the outdoor kitchen.
2013 Chevy 2500, 6.6 Duramax
2013 Lacrosse 318
Gulfrunner is offline   Reply With Quote
Old 05-08-2013, 08:25 PM   #3
Hey Dandy - I had a Tracer 3150 with the outside kitchen, and now a Crusader 335BHS (also w/ the outside kitchen), they both have the same kind of issue you're talking about: some water will get into the lower channel under the door and into the latch for the door. I never had water get into the camper though - the seal always stopped the water, but the latch did end up corroded from water on our Tracer. There's a recent thread about the outside kitchen doors here - link - might want to read through that....
Good luck, and Cheers!
Rig: 2011 F350 CC SB FX4 diesel, aka The Tow Beast
Summer House: 2013 Prime Time Crusader 335BHS
Cheers!
hockey dad is offline   Reply With Quote
Old 05-15-2013, 09:09 AM   #4
I see that the 2014's now have a drip edge over the kitchen door. I believe that will help with this problem. This is another example of how PT does take our input from this forum. I suggested this after seeing it on other manufacturers outside kitchen models. I wonder how hard it would be to install. I wonder if PT would let us order one from them????? I would be interested.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 05-18-2013, 07:19 AM   #5
Commercial Member
FYI - We have run some protos with different applications in the hopes that we continue to improve our product but we are NOT putting any type of drip edges over the outdoor kitchen as standard equipment on 2014 models.
PTM
RV Guy is offline   Reply With Quote
Old 05-19-2013, 06:42 AM   #6
PTM
Sorry, I thought I saw one on a picture of a 2014 318bhs that a local dealer had on their lot. I hate to give out bad info. I looked at it again.....while it is not a drip edge, something appears to stick out farther than on my 318 and looks like it would do a better job rerouting rain water that runs down the side of the trailer.
