Old 06-26-2013, 06:16 PM   #1
Outdoor kitchen leak
Does anyone have a leaky outdoor kitchen door? We have a 360bhs and the door leaks enough to soak a rolled up bath towel during a heavy rain.
cthomas is offline   Reply With Quote
Old 06-26-2013, 08:58 PM   #2
jcoff2003's Avatar
This is a common problem. Search for it on other threads. From what I've read, Primetime says this is normal.
jcoff2003 is offline   Reply With Quote
Old 06-26-2013, 11:13 PM   #3
Were are you seeing the water. We have a 318bhs and haven't seen any water in the outside kitchen. Any pics of were you are seeing the leak??
2012 Lacrosse 318BHS
07 Ford F-350 Super Duty
Hilgy is offline   Reply With Quote
Old 06-27-2013, 06:48 AM   #4
Always Learning
It doesn't seem normal that it is getting things inside wet. I thought what PTM is normal is water getting inside the door itself and draining away. I wouldn't like that my paper towels got wet. Were they on the counter?
Try PM'ing RV Guy, I think it is, to get his attention.
Old 06-27-2013, 11:47 PM   #5
We aren't talking about paper towels here, this is a full size bath towel that I just went to my camper and it was completely soaked!!
Old 06-27-2013, 11:58 PM   #6
ironj's Avatar
where is it getting water? where was towel that was soaked......i too have read of a few complaints of water getting in, but personally i have had 70mph sideways west texas rain pound mine and there were maybe only a FEW drops of water inside the compartment when i opened the door? ....now as far as the whole water inside the door issue, ive seen that, but given the construction and drain holes its really a non issue......just annoying if it falls on your head lol....
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 06-28-2013, 12:10 AM   #7
The rolled up towel is between the door and the rock facing. It only leaks one the right side. Dealer I supposed to replace the door and frame, but no word yet. Meanwhile I drive 35 miles one way just to check on a stupid towel
Old 06-28-2013, 12:28 AM   #8
ironj's Avatar
so under where drawers are? thats where mine gets the drops...no big puddles....i have not looked, but where would water pooling there eventually drain? outside camper or what? il have to look at mine tomorrow when i get it out, but not sure if that would cause an issue long term or not.....does door fit ok and seem to seal?
Old 06-29-2013, 11:27 AM   #9
I get so win mine if I leave it open during the rain. Which I do. Water drips down from the hinges and gets the left side by the fridge a little wet and the receiver for the door latch on that side is rusting a little. I choose to leave it open during the rain though.
When It is closed, though, I'm not getting wet I. There at all...I too have a 318 BHS
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 06-30-2013, 01:31 PM   #10
Commercial Member
For Clarification - Prime Time does NOT think it's normal for water to intrude INSIDE your coach via a baggage door leak. If that's the case, Warranty Procedures with your dealer need to be implemented to get it stopped. It is normal for water to get inside the baggage door and drip thru the weep holes located at the bottom of the door frame. This water should run out of your coach, though, not in.
PTM
RV Guy is offline   Reply With Quote
Old 07-01-2013, 06:39 PM   #11
RVGuy was on top of this one. He is taking care of my issues, can't thank him enough!
Old 07-01-2013, 06:58 PM   #12
Carknocker Family
Ida Ratherbe Camping's Avatar
That was the first factory repair I had to do. Had water everywhere after first little rainstorm. Enough that that some of the wood swelled. I had to recaulk the door. As much as they had smeared everywhere, you would think it have been sealed. But if you looked at it, most was on outside and not in between. What do they do, hand the new guy on the line three tubes of caulk and tell them you can go home when your done? Sloppy, very sloppy.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
