Old 07-09-2012, 04:50 PM   #1
Outdoor TV Mount
I recently purchased a Prime Time Tracer 3150BHD. We absolutely love it, it's quite a learning curve, especially for our first RV.
The unit has a place for an outdoor TV, located between the 2 entrance doors. However I have no clue where to find a mount that a TV can attach to that would fit this pre-mounted piece?
Any ideas?
fightingirish45 is offline   Reply With Quote
Old 07-09-2012, 09:35 PM   #2
HondoPatrick's Avatar
We actually got a mount with our new 318BHS, found it amongst a stack of paperwork. If you didn't get one you may want to contact Primetime and see if the send you one.
HondoPatrick
2012 Ford F250 Lariat FX4
2012 LaCrosse 318BHS w/4 Point Equal-i-zer Hitch
2 Wilderness Systems Kayaks
Nights Spent Camping in 2011 (19), 2012 (16)
http://www.armadillotimes.com
HondoPatrick is offline   Reply With Quote
Old 07-10-2012, 01:15 PM   #3
Commercial Member
FYI - the TV in the 3150 is removable and designed to be taken outside to be hooked up. The bracket already on the TV is the mate to the outside bracket.
The 3150 TV also rotates to the bedroom, so there is no provision in the bedroom for an additonal TV. On the 318 for Hondo, the TV can not be used in the bedroom (doesn't rotate), so we installed an additional TV mounting bracket. That is why you got the extra mounting plate.
If you want an additional mounting bracket, contact Roger in our customer service department at rstickel@forestriverinc.com Depending on shipping, they are normally about $30.
Hope this helps.
PTM
RV Guy is offline   Reply With Quote
Old 07-18-2012, 05:08 PM   #4
Thanks to Prime Time. I was contacted almost immediately after this post and was able to order the part, very quickly delivered.
Love the customer service
Old 08-12-2012, 09:31 PM   #5
How do you remove the tv inside. Did not seem intuitive? Also, can a mount that will fit the exterior mount be purchased at a wal mart?
wna3150BHD is offline   Reply With Quote
Old 08-12-2012, 09:39 PM   #6
BlakeB's Avatar
I doubt you could purchase it at Walmart. To remove the TV your should just have to slide it upward. If it's the same as most FR RV's
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 08-12-2012, 10:12 PM   #7
Just unplug the TV and slide the unit straight upward.
The mount can't be purchased at Walmart but it can be purchased directly from Prime Time Manf. for about 15-20 I believe.
Totally worth it
Old 08-13-2012, 05:06 AM   #8
Thanks! I will try again to slide the interior tv up and remove the indoor tv but I tried that on the dealer lot and because it is mounted inside a wood box (the frame that allows it to spin 360 degrees) it didn't seem like there was much space to move it upward. Hard to believe that the mounts for a second tv are only available from prime time?
Old 08-15-2012, 07:48 PM   #9
Jensen Mounts
I was looking for a mount also and found this link from Jensen, I have not ordered one yet. Try this link.
JENSEN LCD TV Mounts - The Best RV TV mount
nannygoat is offline   Reply With Quote
Old 08-15-2012, 08:41 PM   #10
Phat Phrog Stunt Crew
elind's Avatar
Before you go out and order the TV side of the mount, look around your RV. I was going to purchase that mount when my DW asked me why? She told me I already have one. Sure enough, it was under the bed with other odd pieces of things that came with the TT. If I can't figure something out, ask the wife!
2014 Wildcat 327ck
elind is online now   Reply With Quote
mount, outdoor tv, tv mount
