Old 08-20-2011, 05:19 PM   #1
skgeorgy's Avatar
Outside tap thingy
Hello. Just a question about the water at the main hook up station. I only get cold water out of it. Turn the hot tap and nothing comes out. I checked the valves coming out of the hot water tank and looks like it there isn't a pipe going to it. Is this normal. It is lacrosse 318bhs. Thanks.
Stephen Georgy
2011 Lacrosse 318BHS
2006 F-350
[SIGPIC]
skgeorgy is offline   Reply With Quote
Old 08-20-2011, 05:47 PM   #2
Lottery Non-Winner
Ovair's Avatar
Do you mean the thing that looks and acts like a shower head but is outside near the water panel? All the ones I have seen had both hot and cold.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 08-20-2011, 06:00 PM   #3
skgeorgy's Avatar
That would be the one. It has the hot and cold tap but only water comes out the cold one and nothing at all comes out of the hot.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-20-2011, 06:41 PM   #4
DF5.4's Avatar
Do you get hot water in the TT?
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 08-20-2011, 06:48 PM   #5
I have a different TT, but same set up and mine has both hot and cold coming out
toadswife is offline   Reply With Quote
Old 08-20-2011, 08:50 PM   #6
skgeorgy's Avatar
Yes I have hot water.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-20-2011, 09:00 PM   #7
caper's Avatar
There must be a blockage in the hot water valve. If under warranty take it back to the dealer. If not you could turn off the water to the TT. Then remove valves for the hot water check for any objects in the water line. When the valve is removed apply a small amount of water or air pressure to blow out the line.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 08-20-2011, 09:05 PM   #8
DF5.4's Avatar
Next question. When you turn on the hot water only at the outside, do you get any water? How long do you let it run?
Doug
Old 08-21-2011, 01:05 AM   #9
skgeorgy's Avatar
Got cold water right away. Turn the hot tap. Nothing. Waited 10 seconds.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-21-2011, 07:27 AM   #10
It sounds like they just forgot to run a line to the hot side of the tap. Wouldn't be the first time they forgot something, I am sure.
Old 08-21-2011, 09:44 AM   #11
Try just turning on the hot water side and let it run for at least 30 seconds, or longer (leave the cold water side turned off). Then reverse the procedure - they might be hooked up on reverse with cold actually the hot tap and hot the cold tap.
... VTX-AL
VTX Al is offline   Reply With Quote
Old 08-21-2011, 10:10 AM   #12
rracer5's Avatar
I had the same problem with my 303 RKS. Rather that take it back to the dealer (2 1/2 hours one way), I contacted Prime Time and they were willing to send me a new faucet assembly. I told them to wait until I checked it out further (it was early spring and TT was still in storage). When I de-winterized it, I also removed the interior panel at the rear of the docking station (which is under the bed on the 303 RKS) and found that the HOT water line was kinked between the back of the faucet and where the line goes down through the floor. The line was too long and when they tried to "curve" it to attach to the faucet assembly it kinked. The hose was long enough where I just cut it off below the kink and reattached it to the faucet assembly.
However, keep in mind that as part of Prime Times 25 year leak-free guarantee, they use Oetiker line clamps. Once cut off a new clamp must be installed with special clamp pliers (both available at Lowes or Home Depot), regular hose clamps WILL NOT work.
Hope this helps and good luck.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-21-2011, 10:42 AM   #13
skgeorgy's Avatar
Well sir, you are a gentleman and a scholar. Kinked hot line.
However this wasn't the problem. I guess it is dealer time. Which sucks because I am a month and a half out of warranty.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-21-2011, 11:38 AM   #14
skgeorgy's Avatar
I took a couple of pics of the hot pipes coming from the hot water tank. I looks like the outside hot was missed. The hot that is on the floor goes to the shower and the other goes to the kitchen faucet. Hope I can get this still covered under warranty. 6 weeks out of it.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-21-2011, 07:44 PM   #15
Commercial Member
SK - Although I can't exactly see what your last pic means, what I can tell you is this: If your outside shower doesn't have a hot water line run to it, we will take care of the issue regardless if it's out of warranty or not.
Please contact our service department at this link and let us get to work on this for you.
Prime Time Manufacturing, Manufacturers of travel trailers and fifth wheels
Sorry for the problem.
PTM
RV Guy is offline   Reply With Quote
Old 08-21-2011, 07:50 PM   #16
This post is why owning a Primetime product is so great.
phone man is offline   Reply With Quote
Old 08-21-2011, 08:17 PM   #17
skgeorgy's Avatar
Thanks RV Guy. Again it is great to have your participation. I will follow that link. Never had a need to use the outside shower till now.
Also, all of this posting had been done on my iPhone using the Forrest river app. Whomever designed it did a great job. Not only has this helped me out but is a great time waster.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-22-2011, 11:42 AM   #18
sfrye5853's Avatar
X2
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
