Old 08-20-2011, 05:19 PM   #1
skgeorgy's Avatar
Outside tap thingy
Hello. Just a question about the water at the main hook up station. I only get cold water out of it. Turn the hot tap and nothing comes out. I checked the valves coming out of the hot water tank and looks like it there isn't a pipe going to it. Is this normal. It is lacrosse 318bhs. Thanks.
Stephen Georgy
2011 Lacrosse 318BHS
2006 F-350
[SIGPIC]
skgeorgy is offline   Reply With Quote
Old 08-20-2011, 05:47 PM   #2
Lottery Non-Winner
Ovair's Avatar
Do you mean the thing that looks and acts like a shower head but is outside near the water panel? All the ones I have seen had both hot and cold.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 08-20-2011, 06:00 PM   #3
skgeorgy's Avatar
That would be the one. It has the hot and cold tap but only water comes out the cold one and nothing at all comes out of the hot.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-20-2011, 06:41 PM   #4
DF5.4's Avatar
Do you get hot water in the TT?
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 08-20-2011, 06:48 PM   #5
I have a different TT, but same set up and mine has both hot and cold coming out
toadswife is offline   Reply With Quote
Old 08-20-2011, 08:50 PM   #6
skgeorgy's Avatar
Yes I have hot water.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-20-2011, 09:00 PM   #7
caper's Avatar
There must be a blockage in the hot water valve. If under warranty take it back to the dealer. If not you could turn off the water to the TT. Then remove valves for the hot water check for any objects in the water line. When the valve is removed apply a small amount of water or air pressure to blow out the line.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 08-20-2011, 09:05 PM   #8
DF5.4's Avatar
Next question. When you turn on the hot water only at the outside, do you get any water? How long do you let it run?
Doug
Old 08-21-2011, 01:05 AM   #9
skgeorgy's Avatar
Got cold water right away. Turn the hot tap. Nothing. Waited 10 seconds.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-21-2011, 07:27 AM   #10
It sounds like they just forgot to run a line to the hot side of the tap. Wouldn't be the first time they forgot something, I am sure.
