Old 03-18-2011, 06:36 PM   #1
Picking up Crusader 320RLT on Monday
We are going to pick the Crusader Monday at 1. This is our first NEW one. Does anyone have any suggestions of things to make sure we check and do.
BC11 is offline   Reply With Quote
Old 03-18-2011, 07:20 PM   #2
There is a PDI checklist posted over at Rv.net forum if you do a search...you may want to print it off. Most dealers have a checklist as well. Open every door, work the slide outs, jacks, turn on the stereo,......You may also want to video tape the explanations for operation so you can remember how to do everything....especially troubleshooting instructions if things break. Make sure the keyless works..some have dead batteries while there are short circuits in others.....Good luck and enjoy..you are going to love it.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 03-20-2011, 01:06 PM   #3
2011 Crusader 320RLT
Find out where the water heater bypass is... (and let us know too!) They said it was ready to go when we picked it up.. it had been winterized. We have water, but the water is not going to the water heater. So... we dont have hot water yet. They said they bypass it when they pump antifreeze to winterize it. Cant find it, and we will be calling the dealer again on Monday I guess. (Over an hour away... so not easy to just drop by)
lilspiritus is offline   Reply With Quote
Old 03-20-2011, 01:11 PM   #4
M109Rrider's Avatar
Water heater bypass is behind the access panel inside the front driverside storage door. Take the screws out to gain access. Basically behind the central connection compartment.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 03-20-2011, 01:11 PM   #5
M109Rrider's Avatar
Congrats!!!! Sure you'll enjoy yours as much as we do ours!!!!!
Jason and Billie
Old 03-20-2011, 02:47 PM   #6
lilspiritus - We will find out where the water heater bypass is!
We are hoping the weather is nice so that we don't have to bring it home in the rain!!!!
Old 03-20-2011, 05:24 PM   #7
rracer5's Avatar
I hate it when they show you where the on/off switch is for the hot water heater is but, don't warn you about turning it on without water in the tank. Hopefully, you didn't do this yet. The heating element will burn out in seconds. If so, you will have to operate the heater on propane until the element is replaced.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-20-2011, 06:12 PM   #8
M109Rrider's Avatar
I could be mistaken but I could swear I was told our water heaters won't turn on unless there's water in them.....I may be thinking of something else, can't remember exactly.
Jason and Billie
Old 03-20-2011, 06:42 PM   #9
rracer5's Avatar
Maybe they have incorporated a water level sensor in the water heaters. If so, that's a GOOD thing. But, I don't remember any mention of that during the walk-thru on my unit.
2014 Sanibel 3250
Old 03-21-2011, 01:59 PM   #10
dan747's Avatar
I don't think there is a water level sensor in the hot water tank. They did warn me about turning on the electric heater with out water in it during our walk through. Guess it depends on the person doing the walk around with you. Seems like there should be a checklist used by the dealer while doing the new owner orientation. That's a important gotcha to be aware of.
Dan & Trish
2006 F-250 Lariat 6.0 Powerstroke
2011 Prime Time 260rld Crusader
Columbus 320RS on order
dan747 is offline   Reply With Quote
