Old 03-03-2016, 06:50 AM   #1
Power to slide out problems
I have a 2014 Tracer 3150bh Travel Trailer. I am getting power to my slide out switch but nothing after that. I pulled the motor and it works when separated from the wiring. What could cause this? Please help. I have a wife and two kids expecting to go to Disney today with the camper and we cant go until I get this fixed. Thanks.
Damacdo1 is offline   Reply With Quote
Old 03-03-2016, 06:52 AM   #2
SYE
SYE's Avatar
Having power to the switch and nothing after, makes me believe the switch is bad
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 03-03-2016, 06:57 AM   #3
That's what we thought. We took the switch and put it on the other slide and it worked great.
Old 03-03-2016, 07:08 AM   #4
RSchleder's Avatar
Seems to me if the switch is good, and the motor is good, you have a break in the wires going from the switch to the motor. Have you used a ohm meter to check the continuity between both ends of that wire. You may need an extra length of wire to make either your ohm meter leads or the actual wire your measuring long enough to measure.
If it is the wire ( don't know what else it could be), you could run a temporary wire to get you buy on your trip.
Good luck, let us know how you make out!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 03-03-2016, 07:11 AM   #5
hammer55's Avatar
how about a loose negative, I am not sure what you have, or where everything is located, but some where something sounds missing on the neg side, maybe
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 03-03-2016, 07:13 AM   #6
hammer55's Avatar
yep, true too
Mark & Annie
Old 03-03-2016, 07:49 AM   #7
RSchleder's Avatar
Bad ground is an excellent thought too!! Easy to check with your ohm meter too. 12v systems are notorious for poor grounds causing non-operating systems!!
30 years RV'ing
11 different RV's
Old 03-03-2016, 08:06 AM   #8
SYE
SYE's Avatar
Mine are all up in the battery compartment
Scott & Vicki
2021 4 reserved
Old 03-03-2016, 08:13 AM   #9
hammer55's Avatar
Does the slide have it own ground or do they run it all the way back, I of coarse don't know how it is wired
Mark & Annie
Old 03-03-2016, 11:02 AM   #10
SYE
SYE's Avatar
I am not sure. I would think that they would.
Scott & Vicki
2021 4 reserved
Old 03-03-2016, 11:09 AM   #11
Justice12t's Avatar
Another member had something I would say is similar...a few guys asked him to check for the below and that seemed to fix the issue...
2016 Prime Time Crusader 294RLT
2021 RAM 3500 Laramie Mega HO\CTD, CC, 4x4...ect
Days Camped in last 3 years - 79
Planned Days in 2021 - 50
Days Camped in 2021 - 0
Justice12t is offline   Reply With Quote
Old 03-03-2016, 11:27 AM   #12
Some guy in back...
The pic above is of a circuit break, a resettable "fuse" if you will. I had one rust "open" on a cedar creek several years ago. The technology and the lack of real protection has not changed.
Quick test: Jumper connect the two studs, use the switch for the slide and see if the motor runs. If so, the breaker is open. try resetting it as mentioned, whack it gently to see if that helps, spray with WD40 (aim for the insides) and then whack it.
If it does not reset, You can replace the breaker from an auto parts or marine store or bypass it with a 30A fuse in the correct holder, the fuse connected across the studs.
Good luck!
ChateauV10 is offline   Reply With Quote
Old 03-03-2016, 11:42 AM   #13
Some guy in back...
if that is actually the type of circuit breaker used, the "Shortstop" is a product of Cooper-Bussmann, a large, well-known company in the electrical protection device industry.
Video clip on use: https://www.youtube.com/watch?featur...&v=emckrqicORs
Data sheet: Bussmann Automotive Circuit Breakers - Wiring Products
Still, poor protection (out in the open on a TT tongue, even with the little red boot on) is the #1 cause of failure of these devices.
Old 03-03-2016, 01:02 PM   #14
OP said in post #1 that he has power to the slide switch. Is the resettable fuse located between the slide switch & the slide motor? I would think that the fuse would be before the switch, but really don't know for sure. Just trying to help run down the problem. Sure sounds like the switch may be bad. Just thinking out loud here; hope he gets it straightened out.
He also said no power after the switch.
Papa GLS is offline   Reply With Quote
Old 03-03-2016, 01:16 PM   #15
Carefully check all connections.
Harkerr is offline   Reply With Quote
Old 03-03-2016, 01:36 PM   #16
Some guy in back...
Good point Papa!
I had focused on the breaker, which was the root of my previous problem. it should be located upstream from the switch, so power at the switch should mean it's ok. Still, breaker could fail under load and just be passing enough electrons to show as close to battery voltage but not really any current.
The simplest problem is probably the correct one. I hope he is able to track down the problem!
Old 03-03-2016, 01:53 PM   #17
Justice12t's Avatar
Nice catch, guess I should read closer next time. My apologies. Good luck!
Old 03-03-2016, 03:34 PM   #18
A Last Resort
If all else fails, use the tool to manually crank the slide out / in. That way it won't disrupt your trip plans. My TT came with one that looks like the crank for manual stabilizer jacks. I learned about all this because my slide fuse blew our fisrt trip.... It was a 30 amp located in the main fuse/breaker panel.
Hope you have a fun trip.
Brewdaddy is offline   Reply With Quote
Old 03-03-2016, 04:20 PM   #19
Slide power
Have you checked the controller. It is the electrical component between the power and the motor. I had the same problem with my LR slide. Checked everything and located the controllers in the battery compartment that had shorted out.
Good luck
Mitouko is offline   Reply With Quote
Old 03-03-2016, 09:12 PM   #20
rracer5's Avatar
Well hopefully, he found his problem and got the family off to Disney! No update so......good news?
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
power, slide, slide out
