Old 03-03-2016, 05:50 AM   #1
Power to slide out problems
I have a 2014 Tracer 3150bh Travel Trailer. I am getting power to my slide out switch but nothing after that. I pulled the motor and it works when separated from the wiring. What could cause this? Please help. I have a wife and two kids expecting to go to Disney today with the camper and we cant go until I get this fixed. Thanks.
Damacdo1 is offline   Reply With Quote
Old 03-03-2016, 05:52 AM   #2
SYE
SYE's Avatar
Having power to the switch and nothing after, makes me believe the switch is bad
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 03-03-2016, 05:57 AM   #3
That's what we thought. We took the switch and put it on the other slide and it worked great.
Old 03-03-2016, 06:08 AM   #4
RSchleder's Avatar
Seems to me if the switch is good, and the motor is good, you have a break in the wires going from the switch to the motor. Have you used a ohm meter to check the continuity between both ends of that wire. You may need an extra length of wire to make either your ohm meter leads or the actual wire your measuring long enough to measure.
If it is the wire ( don't know what else it could be), you could run a temporary wire to get you buy on your trip.
Good luck, let us know how you make out!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 03-03-2016, 06:11 AM   #5
hammer55's Avatar
how about a loose negative, I am not sure what you have, or where everything is located, but some where something sounds missing on the neg side, maybe
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 03-03-2016, 06:13 AM   #6
hammer55's Avatar
yep, true too
Mark & Annie
Old 03-03-2016, 06:49 AM   #7
RSchleder's Avatar
Bad ground is an excellent thought too!! Easy to check with your ohm meter too. 12v systems are notorious for poor grounds causing non-operating systems!!
30 years RV'ing
11 different RV's
Old 03-03-2016, 07:06 AM   #8
SYE
SYE's Avatar
Mine are all up in the battery compartment
Scott & Vicki
Old 03-03-2016, 07:13 AM   #9
hammer55's Avatar
Does the slide have it own ground or do they run it all the way back, I of coarse don't know how it is wired
Mark & Annie
Old 03-03-2016, 10:02 AM   #10
SYE
SYE's Avatar
I am not sure. I would think that they would.
Scott & Vicki
power, slide, slide out
