Old 01-29-2012, 11:04 PM   #1
skgeorgy's Avatar
Power tounge jack for Lacrosse 318bhs
Hello all. I was looking to upgrade my hand crank jack to one of those fancy powered ones. Just curious to which size I would need. I don't know if could get away with a 3000 pound one or do I have to get larger capacity one. Thanks all in advance.
3 months till camping season.
Stephen Georgy
2011 Lacrosse 318BHS
2006 F-350
[SIGPIC]
skgeorgy is offline   Reply With Quote
Old 01-29-2012, 11:25 PM   #2
You won't go wrong with the 3500 pound one. Now if you mean diameter, you'll just have to measure and see.
When I hook yup my trailer, I set the tongue down on the ball, latch it. Then pick up the truck and the trailer to connect the weight distribution bars. Usually connect the chains and bars just by hand, no cheater pole required. Then let it all down again. I recommend 3500 pound jack if you connect this way, the easy way. Do the opposite to unhook.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 01-30-2012, 07:44 AM   #3
Wildwood Danny's Avatar
I'd get the 3500 pound, generally not that much difference in price. I also use mine in hooking up, sure makes it easier.
2006 Silverado 2500HD
2007 Hensley Arrow Hitch
Good Sams Club, Cedar Creek Sams Chapter
RVing is a tough job,BUT someone has to do it!
Wildwood Danny is offline   Reply With Quote
Old 01-30-2012, 08:16 AM   #4
I sent you a PM.
Dandy is offline   Reply With Quote
Old 01-30-2012, 08:29 AM   #5
jim44646's Avatar
I put a Barker VIP 3500 Tongue jack on mine. Terrific customer service. Love it
Bought on eBay
jim44646 is offline   Reply With Quote
Old 01-30-2012, 09:38 PM   #6
skgeorgy's Avatar
Thanks for the advice guys.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 01-31-2012, 04:54 AM   #7
I believe that my Touring Edition from last year came with a 4000 pounder.....I would not own an Equalizer without it. As others have stated, drop it, latch it, lift it again, put the bars on, drop it and go....Saves alot of time and energy.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 01-31-2012, 04:34 PM   #8
rracer5's Avatar
And broken toes when trying to "unload" the WD bars without taking the weight off first.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-31-2012, 06:24 PM   #9
I was talking about hookin up...when you lift it after latching I put the bars on..it takes the weight off sorry for not explaining clearly.....
Old 01-31-2012, 08:50 PM   #10
rracer5's Avatar
Yup, I knew what you meant Dave. I was covering the unhooking part when you got to the CG or back home. Raise it up before unhooking the WD bars.
2014 Sanibel 3250
318bhs
