Old 02-20-2014, 07:40 PM   #1
primetime axles
The primetime lacrosse axle owners Manuel says max capacity is 8000 lb. Since the empty weight of trailer its 7900 and cargo weight of 1200 that is obviously over weight for axles. Anybody have troubles with axles breaking. Don't understand why they would put a light weight axle on the lacrosse.
primetime1 is offline   Reply With Quote
Old 02-20-2014, 07:52 PM   #2
Brother Les's Avatar
I am just guessing here, but with two axles..... 8,000 lb. per X 2 = 16,000 lb.a
And also some of the weight is on the tow vehicle.
Brother Les
Old 02-20-2014, 08:06 PM   #3
Do not forget to subtract the weight of the axles.
___________________________________
Salmon Hunter
2011 Crusader 320 RLT/ Honda 3000ei
2006 Chevy 2500HD 4x4 Crew Cab/Duramax Diesel/Allison Transmission
Salmon Hunter is offline   Reply With Quote
Old 02-20-2014, 08:18 PM   #4
Todouble's Avatar
Yes it's 8k per axle. 16ktotal
Todouble is offline   Reply With Quote
Old 02-20-2014, 08:48 PM   #5
Oklahoma Proud
MillerTime's Avatar
I believe some of the weight goes om the tongue. So the axles would have less on them than 7900.
On a side note, I've only seen 8k axles on DRV, Lifestyles and some of the high end, HEAVY 5th wheels. If you had 8k axles your trailer gvw would probably be 17,000-19,000 and empty in the 15k range.
On a tt your axles would be the 8k combined and your tongue is probably around 1000-1200lb? and there is your 1200 cargo cap.
So not overweight on axles unless you overload it or it scales much higher
Old 02-20-2014, 08:58 PM   #6
Platokidd's Avatar
My lacrosse sticker says 4400 lbs front and 4400 lbs rear.
The units dry weight is 8231 lbs and 1406 lbs of cargo. Making the units gross weight 9637 lbs.
About 1100 lbs of that is on the tongue not the 870 the book says I think.. so 8537 divided by 2 = 4268.5 lbs on each axle.
We all know they weigh much more then the sticker says.
I have my weights from the scale somewhere but of course I cant find them now.
Primetime1 what unit do you have?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 02-21-2014, 11:01 AM   #7
another_newfie's Avatar
You didn't post your floorplan and from the available floorplans I can't see an empty weight of 7900 and CCC of 1200. With the being said though, MillerTime and Plaokidd are correct. You will have 4K axles.
It is common to have axles sized like this. I would argue that running right at the edge of the axle capacities can increase the likelihood of axle problems. Especially if you load heavy and/or carry large amounts of FW. In my case I did experience a complete axle failure on my previous (non Prime Time) TT. I feel as though the axle sizing had a lot to do with that.
To your point though, your manual is correct, you have 8K (2 X 4K axles). You can also crawl underneath and get the precise rating from the axle itself.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 02-26-2014, 02:41 PM   #8
didn't think about the second axle. 16000 is correct. I have the pt lacrosse 318. thanks for all the info.
Old 02-26-2014, 02:58 PM   #9
Platokidd's Avatar
Sure its not 4400lbs each axle?
2 8000k axles sounds high.
Sent from my DROID RAZR using Forest River Forums mobile app
nights of camping
Seasonal
Old 02-26-2014, 03:06 PM   #10
Ummm. I think you need to check that again. I am pretty confident that you do NOT have 2 8K axles under a trailer with ~9KGVWR..
axle
