Old 07-06-2016, 10:07 AM   #11
After the calibration the unit will auto level without the need to control it manually however I do get a check stabilize message after it's completedz
esmoglo is offline   Reply With Quote
Old 07-06-2016, 10:20 AM   #12
Look at the top of page 5 of the manual I posted, I believe it is telling you the unit is now level so check your stabilizers (ie JT Strongarms) if you have them installed. I think it is a normal display. Sorry, but I never go look at the display once I hear the level complete beeper go off.
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
Houstonkid is offline   Reply With Quote
Old 07-06-2016, 04:40 PM   #13
rracer5's Avatar
That indicates to me that the system is sensing that one or both of the rear stabilizers does not have equal pressure on the ground compared to the others. I believe you mentioned in a previous post that one rear stabilizer wasn't touching the ground. So, you may have a defective stabilizer or air in the line (if it's hydraulic).
Do you have the 6 point hydraulic "Level Up" system or 4 point with the electric front landing gear?
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 07-08-2016, 09:16 AM   #14
After re-calibration of the system all jacks are touching just fine guess the system looses memory? Used auto level now two more times works fine. What was happening is the left side of the RV was over extending the left rear jack that was lifting up the two tires. I called lippert components and per their recommendation they said to try the re-calibration and it worked like a charm.
Side note worked on the cable issue now I get AIR on all three TV locations and Cable on all three locations in the RV looks like the factory just put the wires together without even trying to get it right not supersized took about an hour to to fix with a cable tester with shunt. Fixing it myself saves me the hassle on taking the unit to the dealer. I allays try to fix any minor issues on my own first.
Few photos from the road this far we are very happy with our 5er...
ID:	113432   Click image for larger version
ID:	113433   Click image for larger version
Old 07-08-2016, 11:17 AM   #15
Glad to hear you are on the road to getting all of your issues straightened out Esmo....Very nice campsites, what part of the world ar you in?
Old 07-08-2016, 01:49 PM   #16
I’m in South FLA, top photo is the KOA music valley drive in Nashville TN, second photo is Silver Springs State Park in Florida and the gas station I don’t recall. We took our 5er from South FL, to central FL, then Stone Mountain GA, Then Nashville TN, Pigeon Forge TN, passed thru NC, then camped in SC, then back to St. Augustine FL, Melbourne FL, and back home to Ft. Lauderdale needless to say the Crusader got a work out.
Last photo is of Beverly Beach Camptown RV Resort we stayed here for 4 nights very nice & right at the waters edge.
Old 07-16-2016, 10:57 AM   #17
I find if I'm not already pretty level (within 1 degree) that my auto-level will try to lift the trailer off the ground. It isn't a very smart system sometimes. I added two graduated levels inside my bay by the controller. Then I use my Andersen Camper Levelers to get within 1 degree and then I auto-level.
Hopkins Graduated Levels
2014 Crusader 296BHS
2015 GMC 2500HD Denali
kohai is offline   Reply With Quote
crusader
