Old 07-02-2016, 07:38 PM   #1
Primetime Crusader Problems
Looking for info we purchased our first 5th wheel camper. We have used it twice
Problems, one slide cut floor about 6", another is leaving scuff marks on floor,Black water tank flush doesn,t work, can't fill fresh water tank, leveling system is off 3" front to Rear, cracks in jelcoat, windows open extremely hard they want to bring back to factory in fall to repair what do people think about this looking for ideas to help out thanks
rogw is offline   Reply With Quote
Old 07-02-2016, 09:55 PM   #2
We have a 2016 Prime Time Crusader and are now just finishing a 17-day trip in six states. Issues that I have found is that my cable is not hooked up correctly I only get the cable to work in the living area and all I get is cable if hooked up at a camp site but no TV by air at all. Other two TV locates bedroom and bunk house only get TV by air and will not get cable no idea why. Second my Auto leveling is not functioning correctly either right rear jack is over extending. If the wheels are not 100% level the system will not level not sure what’s going on. Under both slides the black Darco wrap is starting to show a bit of ware (common problem). My sound bar stopped working as well. Before the trip I did a roof inspection and found three locations were I needed lap sealant. Other than that our Crusader has been ok. I know when you purchase any RV regardless of brand they all have issues it’s just how it is. So far we have spent 19 nights on our new Crusader that was purchased in May of this year. Hope to get the minor issues ironed out because we have a few more trips planned this year.
esmoglo is offline   Reply With Quote
Old 07-03-2016, 07:32 AM   #3
Like esmoglo has stated, they all, rv's in general, seem to have issues. If you read some of the other discussions the problems can occur in any area. I think for Prime Time to agree to repair your faulty items and systems is a real plus. Others seem to have not been so fortunate. We have a 2015 Crusader 294 RLT. it too has had some issues, all taken care of under warranty. Just off warranty now, cap beginning to fade, called Prime Time they said cap has 30 month warranty. We will be having that repainted this fall. Overall, for the price the unit is comparable to many other brands out there. Keep up with PM, and hopefully problems will be minor.
xcopper is offline   Reply With Quote
Old 07-03-2016, 08:12 AM   #4
DDC
DDC's Avatar
I think your dealer is terrible, all of that should have been picked up on a PDI. Sorry you have been left with it, we all expect problems it is a poor system of assembly, how they expect 8 hours of work to be done properly in 3 1/2 to 4 hours so the employee can leave is the main reason for poor quality.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-03-2016, 08:46 AM   #5
I forgot to mention that my black tank i sensor is not wired correctly on the control panel in order for me to get a reading on the black tank I have to switch the panel to Black two and press the gray button and I can get a reading on the status of the tank it should be under the black one or black on the panel but that doesn't work that way. Since I'm able to read it on an another switch I'm just gonna leave it alone that's an easy workaround . I'll be honest with you I don't know how these coaches get tested before they leave the factory because had a more methodical process on checking the systems none of these issues would happen .
Old 07-04-2016, 03:31 PM   #6
Not sure if you are aware but the auto level must be calibrated first.
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
Houstonkid is offline   Reply With Quote
Old 07-05-2016, 01:54 PM   #7
Can it loose calibration? Is this a do it your self kind of deal? I may want to try this before I take it in becasue mine was working just fine now I need to do it manually.
Old 07-05-2016, 02:07 PM   #8
Yes you can do it if you have the same one as I do.
Here is the manual for mine
http://www.lci1.com/images/support/m...ers_Manual.pdf
And here are the specific instructions for calibrating within the manual
Zero setting the control
1.Turn “ON/OFF” button “OFF”.
2.Push “FRONT” button 10 times.
3.Push “REAR” button 10 times.
4.Control will flash and beep, LCD says “ZERO POINT CALIBRATE”.
5.Manually operate the jacks to attain unit level condition (use carpenter’s level).
6.To memorize this level condition , press “ENTER”.
7.LCD says “ZERO POINT STABILITY SUCCESSFULLY SET”.
8.The control will then turn off.
9.Turn “ON/OFF” on to commence operation
Old 07-05-2016, 04:37 PM   #9
Thanks got it will try hope it works VS having to take it to the dealership
Old 07-05-2016, 05:01 PM   #10
Read thru the manual, it has some helpful hints. I printed a copy and keep it on board.
crusader
