Old 06-18-2015, 01:08 PM   #11
rracer5's Avatar
Here's my setup (sorry if pic is sideways). Not shown is a rolled up towel that I stuff in the lower opening to keep "critters & bugs" out. The tight fitting towel also helps relieve the weight of the hose & filter from pulling on the docking station fitting.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 06-22-2015, 08:16 PM   #12
I got a nerf football cut it half way through long ways warped it around my hose and satellite cable and stuffed it in the opening at the bottom of the docking station works great .
tedge is offline   Reply With Quote
Old 07-01-2015, 08:06 PM   #13
I use a 90 degree elbow fitting and attached a quick hose connect fitting on it works great and is very easy to connect or disconnect the water hose.
Kevin & Denise Griffin
2015 Ford F350 Super Duty 6.7 Diesel CC SB, Demco 18K Hijacker Auto Slide, Pace Edwards Electric Tonneau, TST TPMS 507 Standard Sensors, Titan 50 Gallon Midship Fuel Tank
2016 Prime Time Crusader 315RST 5th Wheel, Dometic Slide Toppers
KEG_75 is offline   Reply With Quote
Old 07-08-2015, 06:02 PM   #14
GeoArm's Avatar
We also put a Brass 90 on the city water, and I use the shower hose to hook up to the black water tank flush
2012 Ram 2500 Hemi
2013 PT Crusader 295RST TE
GeoArm is offline   Reply With Quote
Old 07-09-2015, 07:40 AM   #15
rracer5's Avatar
I've found that if you use a dedicated hose directly from the CG's spigot, you get better pressure for the spray nozzles in the tank. If the CG is quiet and you try it both ways, you can hear the difference. Although flushing with HOT water once in a while might not be a bad thing?
2014 Sanibel 3250
295, cat, crusader, location
