Old 06-14-2015, 03:13 PM   #1
sailors's Avatar
Problems with Docking station location in Crusader295
Anyone else having problems with hose connections in the docking station? If so has anyone found a solution? Work area hard to access as door doesn't open fully.
Hope I explained this properly as hubby on way to WM to try to find short hose to simplify the problem.
Thanks.
sailors is offline   Reply With Quote
Old 06-14-2015, 03:17 PM   #2
sailors's Avatar
Our fifth wheel is a 294 not 295 and he did find short hose to attach permanently, so hope problem fixed.
Old 06-14-2015, 04:38 PM   #3
sailors's Avatar
Nope, in a bind so leaking.
Old 06-14-2015, 05:02 PM   #4
Jim34RL's Avatar
Ok here is a wild idea that may work. On my Cedar Creek the black tank flush was missing the rubber washer that is required to seal between the hose and the hose connection in the docking station. This prevents water leaks when the hose is installed. See if the washer is missing or cut simply replace/install one if required. See if this stops the water leak.
Just a guess as I can't see the your unit.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Jim34RL is online now   Reply With Quote
Old 06-15-2015, 12:50 PM   #5
I purchased a hose adapter at CW that looks like a hose bib with a hose. Connection on the bottom making it easier to hook up a hose. I leave it attached at all times a nd. It gives me an extra faucet.
Fufys is offline   Reply With Quote
Old 06-15-2015, 11:41 PM   #6
drelec's Avatar
We have a Crusader 270RET. Because the water hose comes up from the bottom we purchased a brass 90 degree elbow that we leave connected in the docking station. Available at wally world for under $4.
drelec is online now   Reply With Quote
Old 06-16-2015, 08:18 AM   #7
We did the same thing on our Lacrosse 327RES. Works great. And yep....$4 at Walmart.
2914 Tracer 2950BHS
Griswalds is offline   Reply With Quote
Old 06-16-2015, 10:46 AM   #8
Yes I agree with the 90 degree fitting from Walmart that is what I have on
My 295 Crusader 5th wheel .
Fred Jobe is offline   Reply With Quote
Old 06-16-2015, 10:55 AM   #9
clr
I concur the 90 degree brass fitting is the way to go, I also just leave mine installed all the time. That way the hose does not kink when you run the main hose out the bottom of the docking station.
clr is offline   Reply With Quote
Old 06-18-2015, 06:17 AM   #10
Ksilvi's Avatar
We did that too and just leave the 90 degree elbows connected all the time.
2014 Crusader 295rst
2014 F150 Fx4
2017 Cherokee Wolf Pup 17rp
2017 F-150 FX2 Sport
Ksilvi is offline   Reply With Quote
295, cat, crusader, location
